Fuse box - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Electrics (https://www.306oc.co.uk/forum/forumdisplay.php?fid=23) +--- Thread: Fuse box (/showthread.php?tid=16499) |
Fuse box - Sian - 15-08-2013 Adams at work and not answering his phone and I'm a woman so I'm generally paranoid anyway! The fuse box inside the car is ticking? Is that normal! I'm here panicking the car is gonna catch fire haha! RE: Fuse box - cully - 15-08-2013 umm no its not normal RE: Fuse box - Piggy - 15-08-2013 thats relay in there ticking could try opening the fuesbox and pulley out the ticking relay...see what happens. tiz what i would do RE: Fuse box - Sian - 15-08-2013 Hahah!! It's never ever done it before its blowing fuses all the time(windows and sunroof) but never heard the ticking :/ What's that mean? Hahah! I don't even no how to take the fuses out lol RE: Fuse box - Sian - 15-08-2013 Just went out to the car and its still ticking? That's over an hour :/ RE: Fuse box - 4WayDiablo - 15-08-2013 Dies it still start and run OK? RE: Fuse box - Sian - 15-08-2013 Yeah all runs that's why I can't work out where it's coming from ? Seems to have been the brown box in the picture? When I moved it the ticking stopped? But will give it half hour and go check again no doubt it will be ticking again
RE: Fuse box - Piggy - 15-08-2013 could be just a poor earth/connection. worth removing it totally, cleaning the spades and putting it back in RE: Fuse box - Sian - 15-08-2013 On that note Il just pull it out and leave it for Adam to sort if it still ticks il tale everyone of them out haha RE: Fuse box - Piggy - 15-08-2013 its likely something may not work if you do that though...they werent put there for looks! RE: Fuse box - Sian - 15-08-2013 Il go out and look in a bit! Does anyone know what that brown box is for? It stopped the ticking? RE: Fuse box - DarkInferno - 15-08-2013 Quote:Does anyone know what that brown box is for? It stopped the ticking? Quote:It's never ever done it before its blowing fuses all the time(windows and sunroof) but never heard the ticking :/ My bet is it has something to do with windows and sunroof..... But there is a sure fire method of finding out what it is for.... pull it out.. It controls the bit that stops working (you won't damage anything by pulling the relay out..trying everything out.....and replacing it if you need it)
RE: Fuse box - Sian - 15-08-2013 The windows and sunroof don't work anyway! It keeps blowing fuse after fuse! As the wires are all broken in the door! But it's been like that for a while only today it started ticking? Could it be linked like you said? RE: Fuse box - zappa - 14-11-2015 Hi Pug Lovers Is this fuse no 29 30A As I have the same issue keeps blowing Windows do not work I have disconnected both door connections and still it blows the fuse . .......Dose anyone know what the engine running supply means as these are apparently linked with the same fuse no 29 on a 30 fused box. Every thing else is working fine engine starts and runs like f. I am hoping someone can enlighten me on this issue. Regards ZAPPA RE: Fuse box - ghandi0007 - 14-11-2015 (14-11-2015, 07:33 PM)zappa Wrote: Hi rear wiper fooked , grey wire under passenger footwell , disconnect , took my auto spark 6 hrs to find lol |
