How Does this work ??? - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Electrics (https://www.306oc.co.uk/forum/forumdisplay.php?fid=23) +--- Thread: How Does this work ??? (/showthread.php?tid=16307) |
How Does this work ??? - PUGNUT_XS - 09-08-2013 Hi all. This is most likely a Dumb Ass question, Having a look under the bonnet of my 306, there appears to be no wiring that passes through the bulk head, How does the system work, is it some type of transponder system? and is that why you need a unlocked ECU when doing conversions?? How Does this work ??? - Frosty - 09-08-2013 The main wiring goes through under the wiper motor so you can't really see it RE: How Does this work ??? - PUGNUT_XS - 09-08-2013 OK Thanks There just seemed to be no connection from the engine and ecu loom going inside the car. I remember a friend warning me to make sure the drain hole underneath the wiper motor was clear otherwise you would get water in the fuse box. I am slowly learning RE: How Does this work ??? - Danny2009 - 09-08-2013 The engine loom connects on a plug passangers side lower chassis leg near the bottom of the radiator RE: How Does this work ??? - Piggy - 09-08-2013 then that loom runs under the rad support, then up drivers wing, then inside RE: How Does this work ??? - PUGNUT_XS - 09-08-2013 Many Thanks I am looking at putting a GTI 6 Engine in my car, will i have to get the entire loom, fusebox etc?. RE: How Does this work ??? - Piggy - 09-08-2013 just the engine loom |
