PH1 fmic setups - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Photos and Projects (https://www.306oc.co.uk/forum/forumdisplay.php?fid=20) +--- Forum: Photos Of Members / Cars (https://www.306oc.co.uk/forum/forumdisplay.php?fid=15) +--- Thread: PH1 fmic setups (/showthread.php?tid=15971) |
PH1 fmic setups - padge - 29-07-2013 show me yours, need some ideas ![]() RE: PH1 fmic setups - mikey b - 29-07-2013 You have seen mine I spec RE: PH1 fmic setups - underground375 - 29-07-2013 Here's mine first fitted. RE: PH1 fmic setups - silverzx - 29-07-2013 The pikey way: ![]() The proper way: ![]() ![]() ![]() RE: PH1 fmic setups - Jimbo - 29-07-2013 Here's mine ![]() RE: PH1 fmic setups - Frosty - 29-07-2013 My set up ![]() ![]() RE: PH1 fmic setups - padge - 30-07-2013 frosty did you cut a hole on the right side? RE: PH1 fmic setups - Frosty - 30-07-2013 (30-07-2013, 12:59 PM)padge Wrote: frosty did you cut a hole on the right side? yeah I had to cut a hole on both sides ![]() RE: PH1 fmic setups - Tom - 09-08-2013 Anyone got more? Got my kit here and i dont think i can do it with one kit :/ think im going to need more bends ![]() PH1 fmic setups - Frosty - 09-08-2013 I think usually it is a case of using 2 kits. What size pipes you using? RE: PH1 fmic setups - Tom - 09-08-2013 2.25 No way am i buying another kit aha cant afford that! PH1 fmic setups - Frosty - 09-08-2013 Best bet would be to put together what you can and see what you think you need to complete it and then buy the pipes that you need RE: PH1 fmic setups - Tom - 09-08-2013 Or find someone that can weld aluminium ![]() RE: PH1 fmic setups - silverzx - 09-08-2013 2.25 ftw. Never really understood why people go bigger than 2.5"! |
