HDI gear box - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: For Sale (https://www.306oc.co.uk/forum/forumdisplay.php?fid=26) +--- Forum: Misc & Wanted (https://www.306oc.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: HDI gear box (/showthread.php?tid=15869) |
HDI gear box - puglove - 25-07-2013 Provisionally going to say I need a HDI gearbox , I think the diff has gone in my hdi, any one got one they can bring to fcs or drop in to mine on the way to fcs?? RE: HDI gear box - Piggy - 25-07-2013 dang mate. big shame RE: HDI gear box - puglove - 25-07-2013 PITA more like lol RE: HDI gear box - Jonny81191 - 25-07-2013 What makes you think it's the diff? RE: HDI gear box - puglove - 25-07-2013 Jonny FB! I'll explain x RE: HDI gear box - Jaymes306 - 25-07-2013 Should of said the other day mate lol RE: HDI gear box - puglove - 25-07-2013 (25-07-2013, 04:33 PM)Jaymes306 Wrote: Should of said the other day mate lol only found out today lol RE: HDI gear box - darrenjlobb - 25-07-2013 I second what makes you think its the diff? IF IT IS just the diff, you can swap it out without dropping the tranny, but im yet to see one fail! RE: HDI gear box - Piggy - 25-07-2013 I have yet to see one fail too....but he said it was all lose, and couldnt get the shafts in at all despite an hour of him trying! RE: HDI gear box - darrenjlobb - 25-07-2013 :S well either way, you can easily swap that part! RE: HDI gear box - puglove - 25-07-2013 Right bare with me.......I have spoke to ruan on the phone to day who confirmed it is 99% the diff Basically I dropped the box to change the clutch because I had a massive whine coming form the g/box area, assuming it was the push bearing as it was rattly at idel, so I changed the clutch and put the box back on. went to put the shafts in yet I couldn't get either side to go in :S tried for about an hour, nothing! so inspection time. looking into the diff through the drive shaft hole you have two "sleeves" a smooth one after the seal then the splined one the shaft drives from. its dropped about 2/3mm. take the speedo drive housing off the other side same again, stick my finger in there (gigity) and I can push the splined sleeve updown left right all over the place, loose as you like Now im no expert but im pretty sure that spline shouldn't move in there RE: HDI gear box - Piggy - 25-07-2013 as I said when we spoke...that aint right RE: HDI gear box - puglove - 25-07-2013 Just to illustrate what I mean by "sleeve" (I know this isn't the correct diff but the concept id there) And yes james upon getting the box off again there is ALOT of play there RE: HDI gear box - Piggy - 25-07-2013 yeah they should be pretty solid in there. be interesting to strip it down at some point and see the damage RE: HDI gear box - puglove - 25-07-2013 Chris is having the gearbox so wont get a chance to have a look |
