Anywhere that sells egr blanks? - Printable Version
+--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11)
+--- Thread: Anywhere that sells egr blanks? (/showthread.php?tid=15782)
Anywhere that sells egr blanks? - scottbmxer - 22-07-2013
Looking for an egr blank
Thanks
RE: Anywhere that sells egr blanks? - Dum-Dum - 22-07-2013
ebay
Re: Anywhere that sells egr blanks? - scottbmxer - 22-07-2013
I've searched and they don't sell blank plates for an xud engine
RE: Anywhere that sells egr blanks? - ally406 - 22-07-2013
For the inlet I cut a little circle out of a tin of soup and used the end of the EGR pipe, a new clip and some gasket seal to secure it:
[Image: 13.jpg]
[Image: 14.jpg]
...on the exhaust side I made a template out of cardboard the used that to cut the right shape out of sheet steel (although could probably have used the same soup tin!):
[Image: 10.jpg]
RE: Anywhere that sells egr blanks? - martyn92 - 22-07-2013
Good idea with the inlet !
I did the same with the exhaust manifold and used exhaust paste
[Image: 20130526_212826_zps9e02a6d9.jpg]
RE: Anywhere that sells egr blanks? - the milkman - 23-07-2013
Or ph1 manifolds just didnt have egr valves
RE: Anywhere that sells egr blanks? - scottbmxer - 23-07-2013
(23-07-2013, 04:53 PM)the milkman Wrote: Or ph1 manifolds just didnt have egr valves
Managed to get a T2 mani without egr but will I need to blank the inlet as well?
RE: Anywhere that sells egr blanks? - anto - 23-07-2013
Yes.
Yes.
RE: Anywhere that sells egr blanks? - Jimbo - 23-07-2013
Ive got a non egr mani if your going fcs
There you go no bodge jobs needed
