decat on a non turbo - Printable Version
+--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11)
+--- Thread: decat on a non turbo (/showthread.php?tid=15611)
decat on a non turbo - baz306 - 17-07-2013
hi guys i have the 1.9 dw8 engine in my car and was wanting to decat it been reading that diesels rely on back pressure would it be a good idea to decat it or what
RE: decat on a non turbo - Piggy - 17-07-2013
ADMIN: that damn search button has broken again
OP: yea, decat for the win. but bit pointless on a nad
RE: decat on a non turbo - baz306 - 17-07-2013
used the search button couldnt find the answer i wanted
so would it be best just to give it a miss then
RE: decat on a non turbo - mr_fish - 17-07-2013
if you are keen with a grinder and welder, chop your cat out and weld a pipe in. pop the cat down to the scrappy... £££££
However (and I know it has been discussed) some MOT stations will go by 'if it had a cat fitted from factory it should have one for MOT' others will look and as long as the exhaust isn't leaking or rusted through they'll pass the car.
End of the day, up to you.
would the engine run ok with it decatted
would run fine.
spot on mate just what a wanted to know
