broken down. need help asap - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: General (https://www.306oc.co.uk/forum/forumdisplay.php?fid=6) +--- Forum: The Couch (https://www.306oc.co.uk/forum/forumdisplay.php?fid=7) +--- Thread: broken down. need help asap (/showthread.php?tid=15191) |
broken down. need help asap - Just Sean - 03-07-2013 I'm stuck on bedhamptonroad. Cars died. No engine. No apparent damage. Ring me if you can assist!!! RE: broken down. need help asap - Matt - 03-07-2013 Someone stole your engine? :O RE: broken down. need help asap - Just Sean - 03-07-2013 I'm near thorney island RE: broken down. need help asap - Scott - 03-07-2013 If you were up my way I'd have come down, but you're a bit far! What happened just before it died? RE: broken down. need help asap - Matt - 03-07-2013 I'd love to help, but you are close to the wrong island for me RE: broken down. need help asap - rtha6551 - 03-07-2013 (03-07-2013, 04:23 PM)Matt Wrote: Someone stole your engine? :O lmao repped RE: broken down. need help asap - Just Sean - 03-07-2013 Dunno. Powered on to make speed on the slip way. Engine light flashed on and it died instantly. No bangs or pops. No leaks underneath. Still turning over just not firing up RE: broken down. need help asap - Tom - 03-07-2013 Something sensory at a guess lol RE: broken down. need help asap - Scott - 03-07-2013 I've had that a couple of times now. If I lock and unlock the car again, it will start. Have you tried that? RE: broken down. need help asap - vlj - 03-07-2013 Wish you'd have said about an hour ago, was over that way with Geli! RE: broken down. need help asap - Just Sean - 03-07-2013 Thank you Jonny! Your my hero! Aa has plugged in and pulled code p1112. RE: broken down. need help asap - Scott - 03-07-2013 Good to hear it's okay. Removed your phone number from the first post. RE: broken down. need help asap - Dum-Dum - 03-07-2013 Id of come down and helped if id seen this sooner honest RE: broken down. need help asap - Just Sean - 03-07-2013 (03-07-2013, 05:11 PM)Scott Wrote: Good to hear it's okay. Removed your phone number from the first post. Just tried to delete it and you already have, Cheers scot! broken down. need help asap - vlj - 03-07-2013 (03-07-2013, 05:27 PM)Just Sean Wrote:(03-07-2013, 05:11 PM)Scott Wrote: Good to hear it's okay. Removed your phone number from the first post. Don't drink and drive RE: broken down. need help asap - Poodle - 03-07-2013 Yup, P0230 type o' thang. Lol, have fun with that. RE: broken down. need help asap - ginge191 - 03-07-2013 you get going again? i'm round the corner if you're desperate. Have not a clue about HDi's but got tools and a roof if you get stuck RE: broken down. need help asap - Just Sean - 03-07-2013 All fixed now mate. Thanks for the offer RE: broken down. need help asap - Piggy - 03-07-2013 what was it?! RE: broken down. need help asap - Ruan - 03-07-2013 Seriously, are we sure these constant P0230s and P1112s aren't down to lift pumps... You've got a R70, no? RE: broken down. need help asap - Just Sean - 03-07-2013 No Removed the frps and refitted it. Fired up straight away. AA just cleared the codes on the ECU for me! Going to get it of 2moro and give it a little spray with some leccy lube and refit it and cable tie it closed and secure RE: broken down. need help asap - Poodle - 04-07-2013 Basically you panicked cos youre a massive pansy and couldn't fix a flat tyre by yourself. :p RE: broken down. need help asap - Just Sean - 04-07-2013 Yeah. Panic first, fault find second Well, answer the phone to Jonny 2nd! RE: broken down. need help asap - 4WayDiablo - 04-07-2013 That is just round the corner from me lol. Shame I didn't see it How come you're down this way? RE: broken down. need help asap - Just Sean - 15-07-2013 This has happened again! Fml RE: broken down. need help asap - Piggy - 15-07-2013 FRPS?! RE: broken down. need help asap - Just Sean - 15-07-2013 Not sure. Pump wasn't priming and then it did. Think pump is on its way out. FCS is doubtful ATM RE: broken down. need help asap - puglove - 15-07-2013 obviously didn't pay enough RE: broken down. need help asap - Niall - 15-07-2013 (15-07-2013, 03:58 PM)Just Sean Wrote: Not sure. Pump wasn't priming and then it did. Think pump is on its way out. FCS is doubtful ATM Your coming to fcs one way or another. Ill come and get you if i have to! RE: broken down. need help asap - Just Sean - 15-07-2013 Thanks niall! Got track time too! Gutted! |
