Lowering - Printable Version
+--- Forum: Suspension, Transmission, Handling & Braking (https://www.306oc.co.uk/forum/forumdisplay.php?fid=19)
+--- Thread: Lowering (/showthread.php?tid=15124)
Lowering - Mike Southy - 01-07-2013
Hi guys, I've just been offered a set of 60mm lowering springs pretty cheap. Is 60mm too low? Not sure how it would look. Thanks Smile
RE: Lowering - Piggy - 01-07-2013
well if you want to lower you car only by 30/40mm then yes it will be too low.
however if you are wanting to lower you car by 80mm then its not far enough
Re: RE: Lowering - THE_Liam - 01-07-2013
(01-07-2013, 11:57 AM)Piggy Wrote: well if you want to lower you car only by 30/40mm then yes it will be too low.
Sarcastic bastard!
Theres 306s down further than 60mm mate, thats pretty common actually, can't see you having many issues...
RE: Lowering - WiNgNuTz - 01-07-2013
60mm is how much mines lowered by (at the front anyway, backs still standard at the moment, hopefully tackling that soon!), and its just right. Smile
RE: Lowering - kingy - 01-07-2013
60mm is about right imo. Just a matter of opinion and what your taste is.
Re: Lowering - kentiiboii - 01-07-2013
Depends what size wheels you have. I have 17s and cant imagin going much lower than 60mm on front.
Where as if you have 15s you have plenty of room
that can depend on tyre size/profile though. a low profile on 17s could be same outer diameter as 15s with large profile tyres!
RE: Lowering - Darren123 - 02-07-2013
60mm is perfect imo Smile I've 16's with 45 tires and it sits lovely Smile
RE: Lowering - Grant - 02-07-2013
Mines down about 60mm. Only time I encounter problems is with the lower brace on when tackling cushion speed bumps.
RE: Lowering - Mike Southy - 02-07-2013
Awesome, that's good to here, thanks guys Smile It should be lowered by the end of the week. I'll be sure to put some pictures up. I gotta find a decent set of wheels now, i was thinking of 15' steel wheels off a Partner van, in white, thoughts?
