best oil grade - Printable Version
+--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11)
+--- Thread: best oil grade (/showthread.php?tid=15085)
best oil grade - ashkid - 29-06-2013
what is the best oil grade to use in the d turbo on a budget
best oil grade - Frosty - 29-06-2013
10w40 is fine and pretty cheap
RE: best oil grade - Piggy - 30-06-2013
just dont buy supermarket crap
Re: best oil grade - Diggers - 30-06-2013
I used Tescos mineral oil but that's too expensive so im using some oil that came out of a car I serviced. Basically it used 2l of oil in 3/4 weeks and it cos £300 for the estate so could not give a fook. Engines are consumables anyway,
best oil grade - Sambarker - 30-06-2013
10/40 semi synthetic, usually around £15 for 5 litres
RE: best oil grade - ashkid - 30-06-2013
ok great cheers i have only been butting cheap stgudd is as it just gets burnt or leaked as little weep on sump and turbo drinking it Smile
RE: best oil grade - Anton - 30-06-2013
Asda 5w40 Fully Synth, 5 litres £20
you get can decent 10w40 semi synth by a reputable supplier for 20quid
