baz 306 1.9 estate - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Photos and Projects (https://www.306oc.co.uk/forum/forumdisplay.php?fid=20) +--- Forum: 306 Projects (https://www.306oc.co.uk/forum/forumdisplay.php?fid=3) +--- Thread: baz 306 1.9 estate (/showthread.php?tid=15000) |
baz 306 1.9 estate - baz306 - 26-06-2013 well guys since the sale of the car fell through decided to go ahead and fix it all up the car was actually my dads to start with he had it for a few year good few repairs been done the auxiliary belt shredded and came tangled in the pulleys resulting in the camshaft snapping in half the good thing was no bent valves so new camshaft along with new timing belt and water pump peugeot mechanic couldnt find the cause of why the belt shredded. few years later i got the car same thing happened TWICE but i caught it just in time so i decided to inspect the engine and seen that the top auxiliary belt tensioner spring was just holding on by a thin bit of metal the bush was totally gone inside and was causing the belt to sit squint so new tensioner spring and roller was bought and fitted along with new bolts. the rear axle on the car was totally done in so decided to buy a recon'd axle, new stub axle pins, new wheel hubs, new brake shoes, new handbrake cables, new brake hoses and pipes and new abs sensors and set about fitting it on once fitted i decided to lower it about 65mm at the back with some fk shortened dampers at the front of the car i replaced the shocks with some fk shortened shocks and 55mm lowering springs i then replaced the droplinks and track rod ends then i noticed the bleed nipples on the brake calipers were snapped so i decided to source some gti6 brake calipers and eventually found the right ones i fitted with new brake discs and pads. i had a laguna splitter lying in the shed from years ago and fitted it to the 306 which made the car look lower ![]() lowered 55mm front 65mm rear fk shortened shocks front and rear fully recond axle with new hubs/bearings and stub pins new rear axle bushes new rear brake pipes from front to back new rear brake hoses 2 new rear brake cylinders 2 new rear abs sensors 2 new front drop links 2 new track rod ends new front drivers abs sensor upgraded gti6 brake calipers new 283mm gti6 brake discs new gti6 brake pads new auxillary belt top tensioner and spring pipercross panel induction filter custom air intake inlet manifold sealed with high temp silicone gasket headlights masked black new front washer jets back window dewipered under car all treated and undersealed 406 v6 16 inch alloys dressed with 195/45/16 accelera tyres front laguna splitter cut to bumper size next thing am doing is to fix the bodywork 1 or 2 bits of rust nothing major and then get a stainless exhaust installed and then window tints will get pics up later RE: baz 306 1.9 estate - Piggy - 26-06-2013 wow....lot of work! hope its all work it! pics needed! this a NAD? RE: baz 306 1.9 estate - baz306 - 26-06-2013 yip alot of work time and money lol will get pics up tomorrow once ave bled the brakes and had my tyres balanced what do u mean by nad ?? lol RE: baz 306 1.9 estate - cwspellowe - 26-06-2013 Naturally aspirated or boosted? RE: baz 306 1.9 estate - baz306 - 26-06-2013 naturally aspirated for now ![]() RE: baz 306 1.9 estate - Piggy - 26-06-2013 hopefully boosted soon to make all that effort worthwhile! RE: baz 306 1.9 estate - Dum-Dum - 26-06-2013 (26-06-2013, 10:08 PM)baz306 Wrote: naturally aspirated for now I like this plan ![]() RE: baz 306 1.9 estate - baz306 - 26-06-2013 yip thats something to be worked on in the near future just wanting it on the road just now then i'll source some stuff RE: baz 306 1.9 estate - Dum-Dum - 26-06-2013 Where you based mate? RE: baz 306 1.9 estate - baz306 - 26-06-2013 glasgow mate RE: baz 306 1.9 estate - Poodle - 26-06-2013 Blimey you've gone all out on that mate, fair play! RE: baz 306 1.9 estate - Dum-Dum - 26-06-2013 (26-06-2013, 10:20 PM)baz306 Wrote: glasgow mateIn that case I'm not offering to pop over and help with the engine change RE: baz 306 1.9 estate - Piggy - 26-06-2013 (26-06-2013, 10:26 PM)Dum-Dum Wrote:(26-06-2013, 10:20 PM)baz306 Wrote: glasgow mateIn that case I'm not offering to pop over and help with the engine change dumdum, be nice and go help...you've done dummer things....like spent silly time and money to do a hdi cabby only to then sell it...go help him out! RE: baz 306 1.9 estate - baz306 - 26-06-2013 lol thanks RE: baz 306 1.9 estate - Poodle - 27-06-2013 Don't be put out mate, in this instance being miles away from everyone has turned out to be a mercy. ![]() RE: baz 306 1.9 estate - baz306 - 27-06-2013 lol think am the only one on here from glasgow lol well was going to bleed my brakes today but its p*ssing down so thats a no go RE: baz 306 1.9 estate - baz306 - 08-07-2013 here is some pics ![]() RE: baz 306 1.9 estate - Dum-Dum - 08-07-2013 gosh shes looking good, cant wait to get mine RE: baz 306 1.9 estate - baz306 - 08-07-2013 few bits on the body work needing done and the roof rails are coming off next week RE: baz 306 1.9 estate - sam - 08-07-2013 Oooooo looks good ![]() RE: baz 306 1.9 estate - ethanhp1991 - 08-07-2013 Me likey, me likey alot RE: baz 306 1.9 estate - baz306 - 08-07-2013 thanks guys shes slowly getting there RE: baz 306 1.9 estate - Aaron35 - 09-07-2013 Another white estate, brilliant ![]() |
