airbag resistors - Printable Version
+--- Forum: Parts (https://www.306oc.co.uk/forum/forumdisplay.php?fid=25)
+--- Thread: airbag resistors (/showthread.php?tid=14962)
airbag resistors - cully - 25-06-2013
you know what they are for
i do 4 sizes
1.8ohm
2.2ohm
2.7ohm
3.3ohm
price is each
£1.50 +90p P&P for each extra resistor add £1.50+10p
have sold loads of these now via ebay
[Image: 9cc5339c-595e-4763-8a8d-112ddbe22b5d.jpg]
copy of ebay add
For sale
One 2amp fused 2.2ohm Resistor
soldered with fly leads all sealed with heatshrink
can be used for Diagnostics on Airbag systems
or to fool Airbag Ecu into thinking removed bags are present
maybe
youve replaced seats with sports seats and harnesses or replaced standard steering wheel with aftermarket
with the help of this it can defeat the pesky airbag light
one resistor is needed for each removed airbag or pretensioner
it will only work on a working system
It will not work on a system that has logged crash damage and activated
Please be sure this is the correct value resistance for your system
I am not guaranteeing these will work on your car,
i offer no guarantee, or hold no responsibility of damage caused by yourself too yourself or to your car by fitting these
Working on airbag systems can be dangerous
FOLLOW MANUFACTURER PROCEDURES
you are buying
one fused 2amp 2.2ohm Resistor with soldered wire connections
Latest batches of these have bare wire ends, Not the soldered ends
picture shows multiple items
RE: airbag resistors - ginge191 - 25-06-2013
So these just plug into the orange airbag plug? any images of these plugged in? just to get an idea of length and how/where i'd need to sto away the excess
RE: airbag resistors - cully - 25-06-2013
most would cut the plug off and crimp the resistor to the wires
airbag resistors - Jtrigga - 25-06-2013
Would it okay to tuck behind the cowling without it catching on anything for steering wheel airbag?
(25-06-2013, 07:49 PM)Jtrigga Wrote: Would it okay to tuck behind the cowling without it catching on anything for steering wheel airbag?
yes connect it where the squib is plugged in Wink
Thanks mate
RE: airbag resistors - tsotd - 05-06-2015
do you still sell these?
RE: airbag resistors - cully - 05-06-2015
yes i have a few left
i only sell the 1.8ohm version now
£1.50 each +£1.00 postage as a gift via paypal if interested
you can pay the fees and get protection for yourself if you like
RE: airbag resistors - connorp - 09-06-2015
is the 1.8 ohm enough for drivers and passengers air bag and pre-tensioner
RE: airbag resistors - cully - 09-06-2015
yes one for each device removed
airbag resistors - connorp - 01-10-2015
I need 4 please, what's your paypal?
RE: airbag resistors - cully - 01-10-2015
(01-10-2015, 08:52 AM)connorp Wrote: I need 4 please, what's your paypal?
you have PM!
RE: airbag resistors - RetroPug - 01-10-2015
Just to add I had one of these, arrived quickly and worked straight away. No hassle.
Thanks!
airbag resistors - connorp - 03-10-2015
They came yesterday, thanks a lot, got mot and the end of the month and hopefully it will pass
RE: airbag resistors - Ajohnstonec1 - 08-10-2015
Hey Cully,
After the same as Connorp, paypal?
cheers,
Adz
RE: airbag resistors - cully - 08-10-2015
(08-10-2015, 03:08 PM)Ajohnstonec1 Wrote: Hey Cully,
cheers,
Adz
PM sent
airbag resistors - connorp - 10-10-2015
Installed mine with no hassle and they have worked Smile
RE: airbag resistors - cully - 10-10-2015
(10-10-2015, 08:33 PM)connorp Wrote: Installed mine with no hassle and they have worked Smile
excellent Wink
