Help :( - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: Help :( (/showthread.php?tid=14742) |
Help :( - lazareth1 - 17-06-2013 Hi Guys, I was driving down the A1 today when all of a sudden the engine just cut out! Managed to pull into a junction and take a look but the thing just won't start. It cranks over just fine and there's fuel coming out of the filter no problem. I'm thinking the Bosch fuel pump has died a death. Does this happen a lot with these pumps? Just die while you're doing 70 Mph?
RE: Help :( - Ricky - 17-06-2013 I would run a live feed direct to the solenoid on the pump to make sure that's working properly. RE: Help :( - Dave - 17-06-2013 Yeh I would have thought it would be something like that, bosch pumps generally show some pre-warning signs they are going to die, but dieing out of the blue is usually just a fuel cut simple fix - where are you im just off the A1 (long shot!) RE: Help :( - lazareth1 - 17-06-2013 I'm home now. It died on me just before the ASDA junction - Just before Torness Power Station South Bound. Yeah I didn't think these pumps just gave out so suddenly. Where is the stop solenoid? RE: Help :( - Ricky - 17-06-2013 Where the injector lines bolt to the pump, just above them there is a round thing with a wire coming from it. RE: Help :( - 4WayDiablo - 17-06-2013
RE: Help :( - lazareth1 - 17-06-2013 Thanks guys. Will check that or any of the wiring isn't fecked.
