1.8 XS Air filter Box. - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XU Petrol Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=17) +--- Thread: 1.8 XS Air filter Box. (/showthread.php?tid=14637) |
1.8 XS Air filter Box. - MRiches - 13-06-2013 Hey guys, I'm back to ask more annoying stupid questions about air filters! Well, more to the point how to get rid of the 1.8 box. Oh yeh, as you may have guessed I have a new car! WOOP. I'll post some pics in another thread, for now, heres what it looks like. I am aware of the tube connection underneath the box itself, this is what seems to be currently holding it in place, how would I disconnect it? Would I need to get inside the box? ![]() This connecting bit has been losened but it seems tough to get off. ![]() Cheers for help in advance and I'll go now to another section
RE: 1.8 XS Air filter Box. - Grant - 13-06-2013 The second picture, undo the big silver jubilee clip holding the hose onto the Throttle Body. You then mount your air filter to this ![]() NB: You may need a breather filter going to the ICV if your silicone hose for the cone filter doesn't have a port for a tube to be run NBB: Which is the hose coming off your main inlet hose, with the silver crimp clip on it. Can be seen on the right of your second picture RE: 1.8 XS Air filter Box. - MRiches - 13-06-2013 (13-06-2013, 05:41 PM)Grant Wrote: The second picture, undo the big silver jubilee clip holding the hose onto the Throttle Body. You then mount your air filter to this Cheers yeh I thought that's where I would put it, and how to I get those crimp clips off? They seem pretty permanent. It's connected underneath however by the intake hose which I can actually see or get to, was wondering how this would disconnect. 1.8 XS Air filter Box. - callumcull - 15-06-2013 You can get then off by pinching with a pair of adjustable pliers if you don't have the tool for it, or just cut them off and put a jubilee clip in place of them. RE: 1.8 XS Air filter Box. - Piggy - 15-06-2013 small screwdriver in those clips, and twist, they flick off easy. and in general if you just removing it...then just take it apart and it will come off?! RE: 1.8 XS Air filter Box. - C.A.R. - 15-06-2013 If you undo the 10mm bolt on the slam panel to remove the 'snorkel' then it will reveal another 10mm bolt, that one and the one you can already see are what secure the bracket (white corroded metal part you can see) which holds the airbox in place. Undo all 3 bolts and I'm pretty sure the whole thing will lift out. Disconnect the ICV hose obviously, and be careful to plumb it in when you put the new filter on. RE: 1.8 XS Air filter Box. - MRiches - 15-06-2013 Got this sorted yesturday, was easy enough just had to spend a little more time on it. Wondering whether to take out the old hose all together including the original intake or leave it... (15-06-2013, 02:53 PM)C.A.R. Wrote: Disconnect the ICV hose obviously, and be careful to plumb it in when you put the new filter on. Would that be the hose I detached? It's not an oil breather like on a 1.4 is it... If it is just pulling in air the breather I put on it would work just the same. I'm just not sure how this ICV works and what it does exactly. RE: 1.8 XS Air filter Box. - Grant - 15-06-2013 No its the air intake for the Idle Control Valve. Oil breathers are on the cam covers on these engines
RE: 1.8 XS Air filter Box. - MRiches - 15-06-2013 (15-06-2013, 05:17 PM)Grant Wrote: No its the air intake for the Idle Control Valve. Oil breathers are on the cam covers on these engines Ahh awesome, all is well then! Haha. |
