FAO Cully - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Interior, Exterior, ICE (https://www.306oc.co.uk/forum/forumdisplay.php?fid=12) +--- Thread: FAO Cully (/showthread.php?tid=14254) |
FAO Cully - Niall - 29-05-2013 Is this what you meant to do in order to find out if i can use this on my airbags? I am holding you personally responsible if i have to hover up shit loads of dust from my car if i set my airbag off! ![]() RE: FAO Cully - cully - 30-05-2013 oh Dear! no not like that! maybe you shouldnt test an airbag system if you cant use a multimeter yes the FLUKE on ohms range but why the feck is the other meter leads connected to the 10amp connection? should be reading 2 volt Dc scale with the leads in COM-V,ohm,Hz RE: FAO Cully - Niall - 30-05-2013 Oh my bad. Tbh I just got it out the car and forgot to move the lead lol. Will retry tonight. Might not need it anyway. I've found a document on line about the rx8 airbag system and its saying resistance of the bags is between 1.4 and 3.0 ohms so it should sit happily on the 306 system but not sure how correct that PDF is ![]() |
