Another one bites the dust - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: DW10 HDi section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=10) +--- Thread: Another one bites the dust (/showthread.php?tid=14210) |
Another one bites the dust - Jonny81191 - 28-05-2013 Stopped at a motorway services yesterday, and when I got back in the car, she wouldn't start. Sounded like a sticky starter solenoid. Push start and away we go. So this morning I've changed the starter motor and now when you turn the key there's nothing. Dash lights are a bit odd too, the oil and battery light dim when the fuel pump kicks in, and then stay dim. Any ideas guys? RE: Another one bites the dust - darrenjlobb - 28-05-2013 Bad ground / battery connection somewhere, sounds like the engine ground given both those lights are grounded via engine. Put jump lead from batt negative to a good ground point on the engine, and try. RE: Another one bites the dust - Dum-Dum - 28-05-2013 Possibly a f*cked alternator or battery. RE: Another one bites the dust - darrenjlobb - 28-05-2013 Well yeh, im advising on the assumption you have already confirmed batt isnt dead heh... RE: Another one bites the dust - Jonny81191 - 28-05-2013 (28-05-2013, 09:34 AM)darrenjlobb Wrote: Well yeh, im advising on the assumption you have already confirmed batt isnt dead heh... Yeah that's the first thing I'll check tonight
RE: Another one bites the dust - Jonny81191 - 28-05-2013 Darren was right ![]() I've temp fixed it by making a new negative terminal to one of the passenger top mount bolts, then made another one from the driver's side topmount to the top engine mount. Cranks faster too now! RE: Another one bites the dust - darrenjlobb - 28-05-2013 You can always tell when you have engine grounding problems if things are dim / go dim under motoring, but only on sensors / devices that ground via the engine loom. sometimes you notice that steerings makes these lights dim, thats because the grounds so fooked the motors grounding thro the driveshafts / wheel bearings, hence steering alters its connection. RE: Another one bites the dust - Jonny81191 - 28-05-2013 Yeah, just remembered also the EGT gauge kept dropping out too, doesn't do it anymore ![]() Cheers fella. |
