Which clutch/box - Printable Version
+--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11)
+--- Thread: Which clutch/box (/showthread.php?tid=14145)
Which clutch/box - Scott_GT - 25-05-2013
Need to do the clutch but unsure what box I have. The car originally had a NAD engine but it has been changed at some point to a XUD9te but I'm unsure on what box was put on. Would it matter what clutch I fit to it? As long as it fits the d turbo engine?
RE: Which clutch/box - ozonehostile - 25-05-2013
i reccommend using a genuine Valeo clutch, they last much longer than most replacement clutches and cope well with power and torque up to about 150bhp and 250ft/lb
RE: Which clutch/box - Scott_GT - 25-05-2013
are the clutches the same on the d turbo and then nad? i dont want to get the wrong one.
the clutch would be the same yes, the only difference is the gear ratios are sometimes different on the nad
RE: Which clutch/box - Anton - 25-05-2013
Scott im going to MK today, if you need any advice.
