Anyone changed track/tie rods before? - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Suspension, Transmission, Handling & Braking (https://www.306oc.co.uk/forum/forumdisplay.php?fid=19) +--- Thread: Anyone changed track/tie rods before? (/showthread.php?tid=13883) |
Anyone changed track/tie rods before? - Parksy87 - 16-05-2013 Tomorrow im chucking my powerflex arms new ball joints pads n discs on but also changing my tie rods and ends as they were an advisory, anyone done it before and got any tips? Drop the subframe and completely remove the steering rack? For better access? One boot is held on with a clip the other supposedly has a metal ring pressed into it holding it on the rack, buckle it up and replace with a universal boot or anyone have a tip on removing it the proper way? All advice welcome :p RE: Anyone changed track/tie rods before? - londondan86 - 16-05-2013 Are you sure it's not just the track rod ends that need changing? Anyone changed track/tie rods before? - Parksy87 - 16-05-2013 Im sure, they have been an mot advisory, movement/play inner steering joint and i double checked with him that he meant the tie rods RE: Anyone changed track/tie rods before? - Grant - 17-05-2013 You should be able to access the rack from the arches with the wheels off. Are you changing just the rods or the entire rack? RE: Anyone changed track/tie rods before? - Mitch - 19-05-2013 If you turn the steering to full lock, remove the steering boot, and then you should be able to undo the tie rod with a big pair of mole grips ![]() Anyone changed track/tie rods before? - Parksy87 - 19-05-2013 Was going to change both rods, but due to the stud on the ns i didnt attempt it |
