Help please :p - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XU Petrol Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=17) +--- Thread: Help please :p (/showthread.php?tid=13745) |
Help please :p - Adam661 - 12-05-2013 Just brought a gti6 and occasionally more when the engines cold you can set off out of a junction a d put your foot down and there is no power engine doesn't rev up as normal then if you let off and try again it's fine any ideas? I've changed the plugs and fuel filter and fitted a panel filter RE: Help please :p - Tom - 12-05-2013 Throttle cable properly adjusted? Your running lpg arent you? That could make it more difficult to diagnose but im not sure:/ RE: Help please :p - Adam661 - 12-05-2013 Not currently running on LPG so shouldn't effect it RE: Help please :p - Mattcheese31 - 12-05-2013 * affect . . . . .and sorry for being a lady garden but i don't know what your problem is . .(other than bad grammar) . .
RE: Help please :p - Tom - 12-05-2013 I'd guess something to do with the throttle position sensor then? Im no petrol expert though:/ RE: Help please :p - Mattcheese31 - 12-05-2013 (12-05-2013, 04:28 PM)Tom Wrote: I'd guess something to do with the throttle position sensor then? Im no petrol expert though:/ i did think that tbh, i thought that generally made you stall though . .
RE: Help please :p - Adam661 - 12-05-2013 It does sometimes idle a bit lumpy and cut out but not very often idle control valve? RE: Help please :p - Scott - 12-05-2013 An issue with the idle control valve will make it cut out at junctions. Sounds like it could be the throttle position sensor playing up, or something like the MAP sensor. I'm sure someone will be along shortly to confirm
RE: Help please :p - Adam661 - 12-05-2013 What can I use to clean the sensors? And where abouts are they located new to 306s as I'm used to working on saxos
