12 psi... problem - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: 12 psi... problem (/showthread.php?tid=13680) |
12 psi... problem - no2lurch - 10-05-2013 My td is totally standard. Plumbed a boost gauge in just now and Max boost I get it 12 psi. Is that normal? RE: 12 psi... problem - Chris_90 - 10-05-2013 (10-05-2013, 09:40 AM)no2lurch Wrote: My td is totally standard. Plumbed a boost gauge in just now and Max boost I get it 12 psi. You get boost gauge then? I belive standard boost is between 12-14psi so i wouldnt say you have a problem maybe worth checking for leaks tho just incase? RE: 12 psi... problem - Jimbo - 10-05-2013 I think they vary between 12 and 14 mite pay to check d seal on intercooler and tighten Jubilee on turbo pipe onto the cooler RE: 12 psi... problem - no2lurch - 10-05-2013 Gauge arrived yeah thanks. Where and how do I check? RE: 12 psi... problem - scottbmxer - 10-05-2013 Sounds right to me, maybe slighty under tho!! Stock is usually about 14 psi Beat me too it
RE: 12 psi... problem - Chris_90 - 10-05-2013 (10-05-2013, 09:45 AM)no2lurch Wrote: Gauge arrived yeah thanks. Where and how do I check? Get some wd40 spray it around the inlet and intercooler if it revs you have a leak if not then its fine........ get it turned up
RE: 12 psi... problem - scottbmxer - 10-05-2013 Chris what else can you use apart from wd40?? Chris is there anything else u can use apart from wd40? Chris is there anything else u can use apart from wd40? Stupid phone haha RE: 12 psi... problem - Tom - 10-05-2013 Yeah anything flammable! RE: 12 psi... problem - no2lurch - 10-05-2013 just ordered a new d seal for the intercooler! RE: 12 psi... problem - Chris_90 - 10-05-2013 (10-05-2013, 12:25 PM)scottbmxer Wrote: Chris what else can you use apart from wd40?? Yer as said above anything flammable RE: 12 psi... problem - scottbmxer - 10-05-2013 For some reason I thought this only worked on petrol cars lol RE: 12 psi... problem - no2lurch - 12-05-2013 Could leaking exhaust before the cat cause a boost leak? RE: 12 psi... problem - no2lurch - 14-05-2013 changed the intercooler d ring today and it still boosts to 12psi! RE: 12 psi... problem - Anton - 14-05-2013 Came with around 14.7psi (1 bar), but afaik they were set up individually so yours could have just been set lower or lost a couple of psi, hardly alot considering its age! Just tune it RE: 12 psi... problem - Chris_90 - 14-05-2013 Just turn it up job jobbed
RE: 12 psi... problem - no2lurch - 14-05-2013 fuel and turbo is due to be adjusted on thursday! RE: 12 psi... problem - Chris_90 - 14-05-2013 (14-05-2013, 12:53 PM)no2lurch Wrote: fuel and turbo is due to be adjusted on thursday! There you go then job sorted
