Wanted: Headlight Adjust Panel - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: For Sale (https://www.306oc.co.uk/forum/forumdisplay.php?fid=26) +--- Forum: Misc & Wanted (https://www.306oc.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Wanted: Headlight Adjust Panel (/showthread.php?tid=13552) |
Headlight Adjust Panel - rocker8742 - 05-05-2013 After a headlight adjuster panel with the switch + airbag holes in the bottom of the panel RE: Headlight Adjust Panel - Jonny81191 - 05-05-2013 I think I have one. I'll dig it out tomorrow, you coming to PPCITP? Re: Headlight Adjust Panel - rocker8742 - 05-05-2013 I won't be mate, expect the next show ill make is fcs RE: Headlight Adjust Panel - Jonny81191 - 05-05-2013 If I have one I'll post it to you then. £5 plus post? so about £6.50? Headlight Adjust Panel - JamesG - 06-05-2013 I have one £5 posted RE: Headlight Adjust Panel - rocker8742 - 06-05-2013 (05-05-2013, 11:41 PM)Jonny81191 Wrote: If I have one I'll post it to you then. Let me know if you find it mate RE: Headlight Adjust Panel - Dangti6 - 06-05-2013 I've one. Would say collect but unless your passing postage would probably be cheaper Re: Headlight Adjust Panel - rocker8742 - 06-05-2013 Will let you know mate im up your way quite a bit atm |
