MOD: Switch colour LED Mod - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Electrics (https://www.306oc.co.uk/forum/forumdisplay.php?fid=23) +--- Thread: MOD: Switch colour LED Mod (/showthread.php?tid=134) |
MOD: Switch colour LED Mod - cully - 06-12-2011 so your dash has a nice colour led set and all that is left is the white iluminated window switch's with the help of this guide you may be able to change this yourself Tools needed soldering Iron solder small screwdrivers desoldering wick/gun solder coloured LED from the list below the list below includes the maplins part number N66KG 3mm LED White N67KG 3mm LED Red N68KG 3mm LED Green N69KG 3mm LED Blue N70KG 3mm LED Yellow N71KG 3mm LED Orange Switch colour LED Mod Pt1 Drivers door switch push down the 5 higher tabs closest to the top of the switch slowely ease the top off carefully not to loose the spring! Take switch block and release the next ring of tabs careful and hold the block so the connections are on the top slowley ease the connections up leaving the fingerswitch's low this is so the internal switch pads and mirror switch does not escape you should have a circuit board in the other half remove rubber buttons turn block over and locate tads on connection block press tabs in and gently press connections through the base now desolder the line of conections at the front edge of the circuit board you should if youve been good and clean with the iorn lift the board clear clean up connections clean up circuit board remove replace and test leds reaseble board carefully soldering the fron edge connectors reasemble switch and test in car connection drawing for bench testing Re: MOD: Switch colour LED Mod - cully - 06-12-2011 Switch colour LED Mod part 2 Passenger door switch Turn switch over and push tabs in to release switch from bezel take switch and push/lift tabs to release switch head Note LED and resistor you are going to replace turn switch to note the connections to the top board take switch and gently hinge up top board to reveal the solder connections Note direction the led is connected unsolder the pads that the LED is soldered too resolder new LED carefully test the switch LED in the car for correct operation if the led does not light unsolder the led ad reverse it then resolder cut off component legs gentely bend top board back making sure no connections touch the bottom board reasemble switch test in car connection drawing for bench testing Re: MOD: Switch colour LED Mod - cully - 06-12-2011 Switch colour LED Mod part 3 Headlight Leveler push two tabs and slide case off locate led and unsolder resolder new led test then reasemble you might have to bend the led lense to shine onto the white mask symbol central connection drawing for bench testing Re: MOD: Switch colour LED Mod - cully - 06-12-2011 Switch colour LED Mod part 4 Heater control panel this is the heater panal LED mod. you can change the back light colour of the switch and also have a seperat colour for the switch indication, this panal the user wanted red backlight with red switch indication strip out circuit board unsolder Leds and resolder new colours easyer said than done this be carefull when inserting the led in the centre of the switch as the switch contacts are in there too so you don't want the led shorting out the switch remove to car for testing and colours of switch Re: MOD: Switch colour LED Mod - td_dan - 06-12-2011 excellent guide mate just those little touches lol Re: MOD: Switch colour LED Mod - Connor - 06-12-2011 Green Re: MOD: Switch colour LED Mod - 4WayDiablo - 06-12-2011 nice guide! done well! Re: MOD: Switch colour LED Mod - cully - 07-12-2011 colours RE: MOD: Switch colour LED Mod - Cristina - 13-07-2014 My passenger window wasn't working, after some checks my mechanic decided I have to change the driver's side switch. Found one in scrap, replaced it and now found myself with a toy. Started opening it as I have seen on other forums some guys changed the switch bulbs to LED's but not on Pugs. God bless you for this post, lovely pictured and explained. All I need now is a soldering iron, are gas ones good ? RE: MOD: Switch colour LED Mod - nominous - 15-07-2014 For this job even a cheap maplin soldering iron will do. But gas ones can be a royal PITA. Best avoided unless you feel you'll ever need to solder without electric near by. Bearing in mind a soldering iron will happily work off a dirty cheap inverter, so um, never BTW, epic write ups !! RE: MOD: Switch colour LED Mod - Eeyore - 15-07-2014 Avoid gas soldering irons. I got one thinking it would be great but its a pain in the ass and the heat isnt concentrated enough and it will set fire to things if you put it down. Get a decent electric one for £25. RE: MOD: Switch colour LED Mod - cully - 15-07-2014 im not allowed to use gas iorns in work they are an explosion risk for which they are banned RE: MOD: Switch colour LED Mod - puglove - 15-07-2014 Very nice paul , very useful guide Chav........................................... |
