xud conversion.. - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: DW10 HDi section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=10) +--- Thread: xud conversion.. (/showthread.php?tid=11927) |
xud conversion.. - declantg - 15-03-2013 Picking up my xud block and gearbox tomorrow. What else do I need? Here's my list so far Bosch Turbo Intercooler RE: xud conversion.. - ginge191 - 15-03-2013 cambelt kit (water pump, tensioners) clutch kit fluids engine mounts driveshafts subframe the list COULD be endless, what do you already have ? RE: xud conversion.. - declantg - 15-03-2013 Shafts are the same iirc, Like I said got the block and box atm RE: xud conversion.. - ginge191 - 15-03-2013 (15-03-2013, 12:28 PM)declantg Wrote: Shafts are the same iirc, ....and the car this is going into? what i mean to say is, you're doing and XUD conversion - into what? RE: xud conversion.. - declantg - 15-03-2013 Oh sorry! To my hdi x RE: xud conversion.. - ginge191 - 15-03-2013 ohh ok. Mounts i'm not sure if they line up, i wouldn't know. But for the engine itself; cambelt kit (water pump, tensioners) clutch kit fluids and filter (oil, fuel and air flters) Boost gauge auxillaries, if you're using PAS? ermmm ill keep thinking *Exhaust RE: xud conversion.. - Poodle - 15-03-2013 Ive missed something, why wouldnt the mounts line up, theyre both 306 engines, no? Iirc you need clocks, why dont you just call jj? Or whoever did the actual swap for him I guess lol. RE: xud conversion.. - Dum-Dum - 15-03-2013 I dont know about the wiring too much, I think they might actually of used the HDi clocks and everything else worked. Youll need the DTs fuel tank thing (not the HDis lift pump) The mounts, shafts etc all mount straight up id stick with the HDi box The wiring is plug and play on the DT engine loom if you plug it to the n/s chassis leg plugs. Forgotten about water hoses, just have some 25mm pipe about to make hybrid heater matrix hoses and you cant go far wrong. RE: xud conversion.. - declantg - 15-03-2013 Cheers everyone! Better get saving and sorting some bits out! Think I'm gonna get the head off and have it skimmed, along with fresh gaskets. Might as well do it right RE: xud conversion.. - Poodle - 15-03-2013 Good shout, be pretty shit if you got it all sorted then the hg blew as soon as you get on boost lol. RE: xud conversion.. - ozonehostile - 15-03-2013 (15-03-2013, 05:58 PM)Poodle Wrote: Good shout, be pretty shit if you got it all sorted then the hg blew as soon as you get on boost lol. david mowle |
