ph3 on ph2 headlights - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Electrics (https://www.306oc.co.uk/forum/forumdisplay.php?fid=23) +--- Thread: ph3 on ph2 headlights (/showthread.php?tid=11622) |
ph3 on ph2 headlights - spawno88 - 05-03-2013 just a quick one, do the phase 3 headlight fit the phase 3, cheers now RE: ph3 on ph2 headlights - declantg - 05-03-2013 Yeah direct fit x RE: ph3 on ph2 headlights - Jonny81191 - 05-03-2013 Yes. they will but you'll have to swap the adjusters
RE: ph3 on ph2 headlights - Scott - 05-03-2013 They fit fine, though you'll need to swap the adjusters from the phase 2 lights onto the phase 3 lights (so your headlight adjuster in the cabin still works), and possible the headlight stalk. RE: ph3 on ph2 headlights - gareth7 - 06-03-2013 Swap the headlight stalk if you want the crystals work properly.......dipped stays on with main beam if you have a Ph3 stalk, without it dipped will turn off when you change to main. |
