XUD top/bottom end swaps - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: XUD top/bottom end swaps (/showthread.php?tid=11391) |
XUD top/bottom end swaps - the milkman - 26-02-2013 ok from what i can tell and seen so far there shouldnt be to much of a problem with this but just to ask anyone see a problem with using a XUD7 bottom end i.e crank ect and then using an XUD9 block and pistons? of course theres gonna be some difference in ratios but other than that? thanks ash RE: XUD top/bottom end swaps - Ruan - 27-02-2013 Theoretically there's no difference, the stroke is the same on an XUD7 as an XUD9, just the bore thats different... So basically the 9 block and pistons have to go together, I don't think you can use an xud9 head on an xud7 as the valves might not clear but don't quote me on that... Everything else is interchangeable. RE: XUD top/bottom end swaps - the milkman - 27-02-2013 Hmmm thanks ruan. I'll look into it an if I can't find anything about the valve clearance then I'll just try and hope I don't bend more valves than ed's 6 RE: XUD top/bottom end swaps - puglove - 27-02-2013 Im i missing somthing? Is there a point/gain in doing this? RE: XUD top/bottom end swaps - Ruan - 27-02-2013 Valve to piston clearance is fine, its whether they'll touch the edges of the block, I don't think they will... Have you thought about a DW8 head on an xud7 block, that I bet would work.. Just maybe look at the DW8 valve sizes and see if you can put turbo valves in as they're more heat resistant... RE: XUD top/bottom end swaps - Piggy - 27-02-2013 (27-02-2013, 09:55 AM)puglove Wrote: Im i missing somthing? Is there a point/gain in doing this? yeah me too... xud9 lumps are common and cheap?! RE: XUD top/bottom end swaps - the milkman - 27-02-2013 Ah thanks for that ruan big help as usual ![]() RE: XUD top/bottom end swaps - Piggy - 27-02-2013 Ruan da man! RE: XUD top/bottom end swaps - samass - 27-02-2013 (27-02-2013, 11:34 AM)Piggy1987 Wrote: Ruan da man! Christ why don't you buy him flowers already RE: XUD top/bottom end swaps - Piggy - 27-02-2013 is rep not enough?! never know when Ruan is needed...always best to suck up now RE: XUD top/bottom end swaps - puglove - 27-02-2013 (27-02-2013, 12:09 PM)sammykins Wrote:(27-02-2013, 11:34 AM)Piggy1987 Wrote: Ruan da man! He's well past that now. He's at the peeping through the wimdow at night stage now. I need not explain that to you sam. You already know what thats all about. (27-02-2013, 12:39 PM)Piggy1987 Wrote: is rep not enough?! ![]() |
