How much to lower? - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Suspension, Transmission, Handling & Braking (https://www.306oc.co.uk/forum/forumdisplay.php?fid=19) +--- Thread: How much to lower? (/showthread.php?tid=11287) |
How much to lower? - Darren123 - 24-02-2013 Dropping the 306 on 16" speedline comp 2's. What would be the ideal drop front and back? and what size tires should i put on them? How much to lower? - Stephen - 24-02-2013 60mm front 50mm back IMO RE: How much to lower? - Darren123 - 24-02-2013 195/45/r16 tires be ok with that? RE: How much to lower? - Ben - 24-02-2013 Yeah thats the right tyre size RE: How much to lower? - Slam Wagon - 24-02-2013 100mm minimum RE: How much to lower? - Darren123 - 24-02-2013 (24-02-2013, 07:04 PM)PE02KHG Wrote: 100mm minimum Hahaha Bye bye splitter! RE: How much to lower? - miles - 24-02-2013 25 ish all round, any lower and it buggers loads of things up RE: How much to lower? - samass - 24-02-2013 Bumpstops or nothing tbh. RE: How much to lower? - Tom - 24-02-2013 Got to be atleast 60 to look like you've even done anything ![]() Edit, just to clarify, im 70mm on the back and probably 70ish on the front and i weigh a good 100kg and i dont have trouble with speed bumps anywhere, the only place i catch is a specific car park on a harsh slope where the front bumper hits. RE: How much to lower? - Piggy - 24-02-2013 I would say 30/40mm MAX... everyone seems to forget much more and you are seriously impeding the suspension travel and putting from camber out etc...front arms end up at totally wrong angle much lower than 30/40 RE: How much to lower? - Oil-burner - 24-02-2013 Im 40 down and its a pain in the arse at times How much to lower? - Stephen - 24-02-2013 I had 40front 60rear not ideal aesthetically but I had no problems ever, and I live on a farm down a bumpy track RE: How much to lower? - puglove - 25-02-2013 (24-02-2013, 11:45 PM)Piggy1987 Wrote: I would say 30/40mm MAX... only if you do it on the cheap and bodg it , if you spend some money it couses no issue atall , Decent coilovers, Adjustable drop links adjustable top mounts A set of wishbone ball joint extentions ( to put the wishbones back at the correct angle) Take it to a garage to have the tracking camber&caster set , this way being -70mm does the car no harm what so ever and the handling is massivly improved and it looks the tits ![]() RE: How much to lower? - Piggy - 25-02-2013 yeah but he aint taking about doing it at the highest expense...hence my comment you have got a grands worth of work/parts there RE: How much to lower? - Chris_90 - 25-02-2013 (24-02-2013, 11:47 PM)Oil-burner Wrote: Im 40 down and its a pain in the arse at times Why is it a pain in the arse some times? RE: How much to lower? - Pipps - 27-02-2013 Probably because he didn't roll his arches. You need at least a 70mm drop IMO. Preferably more. Take the wheels and front bumper off and roll the arches properly with a rolling tool and a heat gun. Make sure you're running your wheels at the correct offset too. Then you'll have no problem with clearance. RE: How much to lower? - Piggy - 27-02-2013 this is all well and good...but it depends on what budget he has and willingness to do!! RE: How much to lower? - Darren123 - 06-05-2013 So got a mate to lower it ![]() |
