which grease?!? - Printable Version
+--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11)
+--- Thread: which grease?!? (/showthread.php?tid=11271)
which grease?!? - Piggy - 24-02-2013
I am in two, or three depending on my meds, minds over what grease to use...
for the clutch release arm plastic bearings...
I have the following in my grease cupboard:
Lithium
Constant Velocity
General
Copper
White
Ceramic
thoughts??
RE: which grease?!? - Matt - 24-02-2013
A greasey one should do it
which grease?!? - Jonny b - 24-02-2013
Well you won't want copper grease on there bud it has small particles in it, I only use it for anti seizing
RE: which grease?!? - Piggy - 24-02-2013
(24-02-2013, 10:42 AM)Matt Wrote: A greasey one should do it
ahh...that helped Dodgy
Go with the lithium it shouldn't soften the plastic
Read here
http://motionsystemdesign.com/mechanical-pt/lubrication-tips-plastic-gears-0894/
Unhelpful post is unhelpful
I guess I deserved it...my other posts on other threads are useless
(24-02-2013, 10:45 AM)Jonny b Wrote: Go with the lithium it shouldn't soften the plastic
Read here
a good read...doesnt really say what to use though lol
like reading a politicians statement...interesting but not informative!!
Anyway, my thought was the lithium too...wasnt sure if CV was a bit overkill
Yeh go with lithium
It tells you what not to use on plastic though, it's all about what they are based on
RE: which grease?!? - Daniel306 - 24-02-2013
For nylon bushes you should use silicone, lithium is for bearings like the rear beam
RE: which grease?!? - ozonehostile - 24-02-2013
Lithium grease mate, use it at work on plastic components
cheers chaps...reps handed out
