Cheap s16 ECU issues worth a punt? - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XU Petrol Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=17) +--- Thread: Cheap s16 ECU issues worth a punt? (/showthread.php?tid=11146) |
Cheap s16 ECU issues worth a punt? - lewisdmz - 20-02-2013 A family friend has contacted me to say they have an s16 which won't start. They have taken it to a 'specialist' who has said it needs a new ECU and have quoted them £600 odd to sort it out. Whether this means the ECU is fried or just needs flashing/unlocking or something I don't know. Has tax and MOT, owned by a couple, completely standard and apparently in good condition (haven't seen any photos or anything though). No idea about panels/interior. They are going to have it scrapped and said I could have it for about £150, worth it's money in parts easily but I can't break it due to space and it's undriveable at the moment. Going to do some research tonight as I have no idea about how these work, could you buy a 2nd hand ECU and match it to the immobiliser? Could just be an immobiliser issue? RE: Cheap s16 ECU issues worth a punt? - Niall - 20-02-2013 sod paying that. Get a key, ecu and bsi from another car! Oh and moved to the correct section
RE: Cheap s16 ECU issues worth a punt? - kernow_joe - 20-02-2013 if you don't want it I'll come up with trailor and look after it
RE: Cheap s16 ECU issues worth a punt? - lewisdmz - 20-02-2013 Unfortunately it's all the way on the Isle of Wight Joe! Pain in the arse eh? RE: Cheap s16 ECU issues worth a punt? - lewisdmz - 20-02-2013 What's the deal with the transponder? I'm guessing that is linked to the BSI and will also need to come from the donor car? RE: Cheap s16 ECU issues worth a punt? - miles - 20-02-2013 Just use a unlocked ECU or a pre keypad 306 which the early S16's where, Got a few if you need any, or if they want it fixed drop it off to me RE: Cheap s16 ECU issues worth a punt? - Josh_Quant - 24-02-2013 I bet its not even the ecu! bet it something like engine control relay |
