Comparing turbos - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: Comparing turbos (/showthread.php?tid=11067) |
Comparing turbos - David - 19-02-2013 For you turbo geeks out there who know loads about turbos I have question What's k03 like compared to a td04? What does it spool at? What's the max boost? And will it be any better at long journeys cruising at 80? RE: Comparing turbos - Ruan - 19-02-2013 Completely depends on the K03 used, there's many different variants of the K03 - just like saying "TD04" - it really means very little unless you give it's whole name "TD04L-13T" - The K03 off a stock DT is pretty wank and will barely make 135hp without popping, whereas there's other "K03"s that will do much more than that... RE: Comparing turbos - David - 19-02-2013 Oh sorry mate. I'm running a td04-13t and the k03 is a k03-35s11 RE: Comparing turbos - ginge191 - 19-02-2013 K03 all the way. /thread
RE: Comparing turbos - Ruan - 19-02-2013 Ginge, can you stop being a dick now? Comparing turbos - Jake - 19-02-2013 Is that vnt Mowle? RE: Comparing turbos - Ruan - 19-02-2013 35s11 isn't I don't think... RE: Comparing turbos - David - 19-02-2013 An it's not a vnt RE: Comparing turbos - Chris - 19-02-2013 Its off a 2.3 Iveco, Its equivalent in size to a gt1752 give or take a mm or so. |
