Bit stuck - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: Bit stuck (/showthread.php?tid=10427) |
Bit stuck - sam - 03-02-2013 Right before I took the pug off the road (blew the t2 up) now its all back together with the fmic on its stuttering/missfiring i think and blue smoke but inly when it stutters any reason for this? RE: Bit stuck - ozonehostile - 03-02-2013 when the turbo blew up, did you have an oil explosion too? have you checked the ic piping for oil residue? RE: Bit stuck - sam - 03-02-2013 Nope just stuttered Not yet RE: Bit stuck - ozonehostile - 03-02-2013 and youve only had the turbo off havnt you? RE: Bit stuck - sam - 03-02-2013 Old off new on dont make sence though RE: Bit stuck - 4WayDiablo - 03-02-2013 When mine done exactly as you described it ended up being the fuel filter? Although how that's changed since turbo I have no idea RE: Bit stuck - Arron - 03-02-2013 My 1.9 used to do that if stood for longer than a day. Just took it for a spirited drive and once it warmed up for a few mins it would stop RE: Bit stuck - sam - 03-02-2013 Ok nice one about to chamge the fuel filter to see what thatll do
RE: Bit stuck - sam - 05-02-2013 Replaced the fuel filter aynd its still doing it? Less smoke though RE: Bit stuck - Matt - 05-02-2013 Take it for a hoon. Sorts everything RE: Bit stuck - sam - 05-02-2013 Have done mate flat out to and back from Gloucester yesturday :/ RE: Bit stuck - Ricky - 05-02-2013 So it drives ok with no smoke? Just stutters on idle? I would check all pipes, and maybe get a compression test done. RE: Bit stuck - sam - 05-02-2013 Drives ok, there is abit of blue smoke but I dont no if thats the oil in the exhaust from the old turbo, yeah stuters on ideal sounds like its missfiring if that makes sence? Ill ring my mate and see when he can do a compressoin test for me I found the problem I have a dodgy injector so gunna buy new ones next month
RE: Bit stuck - puglove - 05-02-2013 Thats it sam give up. I'll come round take it off your hands. I wont even charge you for it
RE: Bit stuck - sam - 05-02-2013 Haha not in a million years well maybe in the summer haha
