S16 idle - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XU Petrol Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=17) +--- Thread: S16 idle (/showthread.php?tid=10338) |
S16 idle - Frosty - 30-01-2013 Yes I know it's that frosty again with another problem with his S16. Well as you guys were so helpful with helping me sort out the flat spots I fort I would test you brains again. Basically I have had this problem for a while but only does it very now and then but it seems to be doing it a lot at the moment. When it's idling it kind of revs it's self up and down. Goes to about 1250rpm and down to about 700rpm. And when I'm driving along and then come to stop/slow down with the clutch down it cuts out. I guess that link though as I expect the revs are dropping to low and there for it cuts out. Any ideas what the problem is? Help much appreciated RE: S16 idle - swampy - 30-01-2013 Idle control valve Big silver canister on left hand side of cylinder head has an electrical connector on top and a hose or two coming off the bottom RE: S16 idle - Strikeforce - 30-01-2013 +1 on the icv S16 idle - Frosty - 30-01-2013 (30-01-2013, 09:54 PM)swampy Wrote: Idle control valve I will have a look in the morning. Got a pic of what I'm looking for? So it to a case of replace it or can it be cleaned RE: S16 idle - swampy - 30-01-2013 You can't miss it, around same area as the oil filler cap. The hoses that cone off it are breather hoses so it does get gunked up with crap Also check the pipe work attached to it isn't split S16 idle - Frosty - 30-01-2013 Ok cheers mate. Will check it out tomorrow . S16 idle - Frosty - 31-01-2013 So I give it a bit of carb cleaner stuff at work today and I'm just going to see how it is now as it only does it every now and then Re: S16 idle - aggyj17 - 31-01-2013 I have a spare idle control valve if you need one. S16 idle - Frosty - 31-01-2013 I've got 1 on the spare engine I got but thanks anyway. Hopefully it's sorted anyway |
