Temperature gauge - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: DW10 HDi section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=10) +--- Thread: Temperature gauge (/showthread.php?tid=10163) |
Temperature gauge - Tony172 - 25-01-2013 My temperature gauge doesn't seem to move much even after a 170 mile drive its still right down by the bottom, also,the heaters don't blow very hot air, it's warm but not overly warm Is it a gauge fault? I'm pretty sure it's not a thermostat problem otherwise engine would over heat? RE: Temperature gauge - fuziduck - 25-01-2013 Sounds like the thermostat is stuck open. Thermostats failsafe to open which will cool constantly rather than to shut and potentially overheat the engine. Thermostat seems like a reasonable place to start, but bare in mind HDi's do run relatively cold. Mine never got above 84C on the OBD reader. Interior heaters got warmer than warm, but never hot. RE: Temperature gauge - Tony172 - 25-01-2013 Ok mate cheers for that, the temp gauge doesn't seem to move at all! Would that cause it to stay on cold map? RE: Temperature gauge - ozonehostile - 25-01-2013 im sure this was the first thing you checked, but have you checked the coolant level? if the level is too low the sensor isnt covered therefore wont read anything. also could possibly be an airlock in the coolant. something to look into. if its non of these things my money on a blocked heater matrix as for why you dont have any heat RE: Temperature gauge - Toms306 - 25-01-2013 Mine barely ever rises above 70c. Cully says the cold map stops at 69c, so the majority of the time its on cold map for me as it takes a good 15 miles or so to hit 70! Oh and the heaters are rubbish as well, even when the blower does decide to work......but that may be because I was used to heaters in a better car before lol. RE: Temperature gauge - cully - 25-01-2013 get some diagnostic equipment on there as the hdi use's a second temp probe to measure the temp for ECU reference so the gauge sensor may be faulty but the Ecu sensor could be good compare the two to prove the gauge is telling the truth both sensors are in the same package (blue plug right hand side of block in the thermostat housing) but its probably the thermostat is stuck open like fuzi has said RE: Temperature gauge - Tom - 25-01-2013 Change the thermostat, re bleed and report back ![]() RE: Temperature gauge - Tony172 - 25-01-2013 Yeah coolant is full and heaters blow warm air ill get the thermostat changed and report back to you cheers guys RE: Temperature gauge - Poodle - 25-01-2013 Don't think you'll be far wrong with changing the thermostat, hope it sorts it for you. (25-01-2013, 05:38 PM)Toms306 Wrote: Mine barely ever rises above 70c. Cully says the cold map stops at 69c, so the majority of the time its on cold map for me as it takes a good 15 miles or so to hit 70! Temperature gauge - kentiiboii - 25-01-2013 I think my hdi could do with a thermostat. It only just reaches the white mark for 70c. Heater are warm but not hot. I know my old hdi used to sit about 80c. Thermostat is on list with service and new coolant ![]() |
