Cold map?? - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: DW10 HDi section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=10) +--- Thread: Cold map?? (/showthread.php?tid=10161) |
Cold map?? - Jonny81191 - 25-01-2013 Since fitting my new turbo, I've noticed that when I set off in the morning and also to go home from work, I have no power, feels exactly like I've blown a boost hose off. It also appears to be struggling to make any boost, the gauge shows very little at all, sub 8 psi at a guess. As soon as it starts to warm up (maybe 2 mins driving) the power comes in all of a sudden and it's fine, no issues and drives really nicely ![]() It's worth noting that I always take it really easy on a cold engine, I'm not trying to get much from it, but this really is weak. Also that I still have no air intake piping, so even though the MAF is plugged in, it won't be giving correct readings, if any. I'm guessing that this is just the cold map, and the fact that this turbo is just a little bit more laggy, it's making it really obvious. But any thoughts would help! RE: Cold map?? - ginge191 - 25-01-2013 Because you have electrics controlling your engine; fail already.... sorry mate. gotta scrap it in RE: Cold map?? - Jonny81191 - 25-01-2013 Because you have a 306... owait. RE: Cold map?? - ginge191 - 25-01-2013 touché ... but is that someone REALLLY to be proud of ![]() RE: Cold map?? - Poodle - 25-01-2013 Could well be the cold map with no maf, would test it for you, but mine goes into limp when i unplug it. ![]() RE: Cold map?? - Matt - 25-01-2013 *something And yes. Something to be very proud of haha. RE: Cold map?? - Oil-burner - 25-01-2013 (25-01-2013, 02:06 PM)Matt Wrote: *something Damn right! RE: Cold map?? - Toms306 - 25-01-2013 Cold map with a broken MAF is terrible, trust me on that lol. Tried unplugging the MAF if it's not already unplugged. Makes it a little better.... RE: Cold map?? - tb205gti - 01-02-2013 There is no such thing as a "cold map" unless the person who has remmaped it (is it remapped?) manually made it - and I highly doubt it. Disconnecting the maf will make the ECU run by pre-set MAF values - this is okay'ish, far from perfect, but it will run with it. Some of the remaps around will smoke badly if you disconnect the MAF, it all depends on how it has been remapped. Like Poodle says some of them will enter limp when the MAf is disconnected, it depends on the Sw used. Some will only log a silent error, and some will throw a full limp mode and MIL. Who mapped it? RE: Cold map?? - Jonny81191 - 01-02-2013 AFAIK you mapped it ![]() It's DumDum's old estate. Either way it works fine now I have a MAF plumbed into the air intake. RE: Cold map?? - tb205gti - 01-02-2013 HAHA - I'll take a look at the remap. ![]() Always use the MAF, or disconnect it alltogether, never use it plumbed in - but not in the airstream to the engine. RE: Cold map?? - Mr Whippy - 01-02-2013 I was gonna say, having a MAF plugged in but not in the air flow is not gonna make things happy. MAF unplugged or not working is still not ideal either really. MAF is a good thing to have there and working properly. Dave RE: Cold map?? - Toms306 - 01-02-2013 (01-02-2013, 08:05 AM)tb205gti Wrote: There is no such thing as a "cold map" unless the person who has remmaped it (is it remapped?) manually made it - and I highly doubt it. Why is it very noticeably slower when cold then? I was always under the impression you need more fuel when cold as some of it sticks to the cylinder walls or is lost down the sides or the piston. Maybe not a different map altogether, but must be some difference in the map when the engines cold? RE: Cold map?? - Ruan - 01-02-2013 In fairness I thought there was a ect limiter in use... I've not studied HDi maps at all really, but I thought there was one, though is it just when the coolant gets TOO hot it limits iq? RE: Cold map?? - tb205gti - 01-02-2013 (01-02-2013, 01:17 PM)Toms306 Wrote: Why is it very noticeably slower when cold then? There are a lot of compensator maps that gives a slightly richer mixture when it is cold, because internal losses are greater when the engine is cold. The injectors hit the bowl in the piston, if they hit the cylinder walls - you have a serious defect ![]() but there is not a set of maps that define a "cold map" in it - unless you make that yourself. RE: Cold map?? - Toms306 - 01-02-2013 With the state of the injectors in mine god knows where the fuel is ending up. ![]() However now Ive thought about it, it was from an assignment I done, but it was the reason that direct injection is better than indirect in petrol, probaly applies to diesel as well though, but yes I see your point. Im slightly confused though, you say there isn't a cold map (or set of)...yet there are maps that give a richer mixture when cold.....whats the difference? ![]() RE: Cold map?? - tb205gti - 01-02-2013 (01-02-2013, 06:24 PM)Toms306 Wrote: With the state of the injectors in mine god knows where the fuel is ending up. Sory English os not my mothers tongue. When you remap it - you do not have a "cold map" that you modify that then is used solely for when the engine is cold. but there are a bunch of compensator maps that will alter the fuel depending on the inlet temperature, coolant temperature, diesel temperature and on some oil temperature. ..But they are also used to cut back on the diesel when the engine gets (too) warm. Does it make sensor, or am I talking out my arse? ![]() RE: Cold map?? - Toms306 - 01-02-2013 Ah ok, yes I see what you mean, that does make sense. ![]() |
