Sensor fuel filterhousing - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: Sensor fuel filterhousing (/showthread.php?tid=10110) |
Sensor fuel filterhousing - 306__xrdt - 23-01-2013 Hi i just wonder what kind off fuel filter sensors there are on the fuel filter housing? Peugeot 306 XRDT 1993. Thanks Sensor fuel filterhousing - Frosty - 23-01-2013 There is 1 sensor on it that's to tell you if there water in the fuel filter I think. It puts a light on the dash that's like a test tube RE: Sensor fuel filterhousing - Mattcheese31 - 23-01-2013 (23-01-2013, 04:54 PM)Frosty Wrote: There is 1 sensor on it that's to tell you if there water in the fuel filter I think. It puts a light on the dash that's like a test tube what he said . . .^^^^^^ . . RE: Sensor fuel filterhousing - 306__xrdt - 23-01-2013 Ok thanks for answer sometimes it is difficult to start and the same time the light goes on indicating there is water in the fuel, but i have several times drain for water true the tube but still the light goes on so i quess there is a fault in the sensor. Any idea what the name for the sensor is? water warning light sensor? Or fuel sensor? i have no idea what the name is for the sensor Thank you for feedback |
