Ozonehostiles Blurple gti6. - Printable Version
+--- Thread: Ozonehostiles Blurple gti6. (/showthread.php?tid=22207)
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35
Ozonehostile vaguely oem+ Gti6 - Razorback_Rob - 09-06-2014
(09-06-2014, 10:07 AM)Piggy Wrote: c'mon...show us the rot!
It ain't a pretty sight Sad
RE: Ozonehostile vaguely oem+ Gti6 - ozonehostile - 09-06-2014
(09-06-2014, 10:04 AM)kentiiboii Wrote: Looked great zakk! Never got chance to speak to you as I never saw you.
How did you set the linkages up, just the same length as the old ones?
Did them fractionally shorter than the standard items just to take out any slack that was in the movement of the gear selectors. Feels perfect now.
If you can, get the car on a ramp to fit them, space is pretty tight on a '6 lump and I certainly wouldn't like to remove and fit linkages lying under the car
Oh yeah, had the car on the ramp yesterday fitting new parts and seeing all was well after the fcs trip and I found this:
[attachment=16701]
It wasn't a hole until I bashed it a bit and wire brushed it clean but looking under the car with a torch noticed a fresh looking patch of underseal and found it to be crusty underneath. The metal around it is still solid, just a 50p sized hole, cleaned it all off for now and coated it in primer, hopefully be able to get it welded this week and change the n/s cv boot that's developed a pinhole since fcs.
Re: Ozonehostile vaguely oem+ Gti6 - kentiiboii - 09-06-2014
Ouch, not good finding a hole. I have a rust patch in drivers side arch that I need to clean up and seal.
Ok mate cheers for that, I have some on the way from baker bm as they ran out when I got there.
RE: Ozonehostile vaguely oem+ Gti6 - RetroPug - 09-06-2014
Shame about the rust but apart from that, looking really good!
(09-06-2014, 12:31 PM)RetroPug Wrote: Shame about the rust but apart from that, looking really good!
Fingers crossed it's the only rust too!
After finding it I went right around the car again checking for more and it's looking good. We did find a patch when the new beam was going on but sorted it then.
The problem here has been caused by the previous owner the whole underside has been doused in waxoyl which is a good thing I guess apart from he didn't treat what then would have only been a patch of surface rust I guess
RE: Ozonehostile vaguely oem+ Gti6 - ozonehostile - 12-06-2014
Welding booked for Saturday morning :-)
Changed the weeping cv boot last night, absolute joy to work on this car, everything greased up and comes apart effortlessly, took about 20 minutes from getting the wheel off to doing the hub nut back up haha
[Image: IMG-20140611-WA0020_zpsp7rrxonp.jpg]
Went for a quick hoon across the border since it was a nice evening, going down through the gears coming to a roundabout something metallic fell off and heard it ping off down the road, nothing obviously broken or missing after a roadside inspection but still not something you want to hear whilst driving haha.
I'll investigate tonight
RE: Ozonehostile vaguely oem+ Gti6 - silverzx - 12-06-2014
Hah, must be be all that grease mate! Tongue
RE: Ozonehostile vaguely oem+ Gti6 - Piggy - 12-06-2014
I took out a catseye on the way home from FCS...sounded like something HUGE hitting the underside of the car! lol
by the way mate, that ramp looks dodgy, holding the car on its side Wink
RE: Ozonehostile vaguely oem+ Gti6 - RetroPug - 12-06-2014
Could just be a clip or bolt that someone/you dropped that was kicking around in the engine bay somewhere. I've removed things and found clips and bolts sitting about under stuff before, and I'm sure I've left a few around.
Well I've had a good look and nothings missing, must have just been a bolt or something I dropped in the undertray
Went for a hoon just to make sure [Image: IMG_20140612_204306_zps31848zl1.jpg][Image: IMG_20140612_204558_zpscmvjgdxd.jpg]
Wheres that?! Dont recognise that road at all
(12-06-2014, 08:57 PM)Piggy Wrote: Wheres that?! Dont recognise that road at all
Monmouthshire/Powys are minutes away from my house in either direction :-P
Only ever 10 minutes away from hooning nirvana
That particular Road has been shut since before Xmas because of a huge landslide, it's one of those roads that doesn't really go anywhere and it's completely closed off now. 5 miles of up hill corners with zero traffic <3
Ozonehostile vaguely oem+ Gti6 - Razorback_Rob - 12-06-2014
I recognise that road too dude where's it near?
RE: Ozonehostile vaguely oem+ Gti6 - Curt - 12-06-2014
Car really does look great.
(12-06-2014, 09:24 PM)Razorback_Rob Wrote: I recognise that road too dude where's it near?
Kentchurch - Grosmont.
Must have been some good noises echoing down from the hill a few hours ago :-P
(12-06-2014, 09:31 PM)Curt Wrote: Car really does look great.
Cheers man, just need a fresh bumper and ph3 strips, then I'll be happy haha
Is amazing down that way. Roads over between hay and ewyas Harold are intense too as we know :p
RE: Ozonehostile vaguely oem+ Gti6 - ozonehostile - 14-06-2014
Early start today for gti6 surgery... massive thanks to my pal Jamtech motorsport for the welding (the guy who has got my 106 rallye as his next job)
pictures:
[Image: 984111_753069584713791_70303979891330562...598283.jpg]
[Image: 10419032_753069561380460_245472029288311...ee8d33.jpg]
[Image: 10448743_753069738047109_836462948311462...f9255a.jpg]
[Image: 10367187_753069628047120_717275645525862...742b1a.jpg]
[Image: 10390301_753069714713778_515881698933093...49fd15.jpg]
[Image: 10303785_753069834713766_677083920956772...28d4a4.jpg]
treated the rest of the area you can see rust starting while it was all stripped back, now all seam sealed, primed, painted and stonechipped but no pictures of that because my battery died.
also cleaned up some more of the floor pan and under sealed down the sills and around the jacking points, starting to look pretty nice under the car now haha
RE: Ozonehostile vaguely oem+ Gti6 - Niall - 14-06-2014
This. Very simple but very clean and tidy. Even if it is Nile blue :p
haha thanks man, and i think we should start calling it Blurple :p
RE: Ozonehostile Blurple gti6 - Tom - 15-06-2014
That first pic in post#250 is f*cking epic! <3
RE: Ozonehostile Blurple gti6 - RetroPug - 15-06-2014
(15-06-2014, 09:32 AM)Tom Wrote: That first pic in post#250 is f*cking epic! <3
Looks like it's just patiently waiting to be flying down the road ahead!
RE: Ozonehostile Blurple gti6 - Poodle - 15-06-2014
Looks incredible dude, really super clean.
So, about that truck turbo... Wink
RE: Ozonehostile Blurple gti6 - ozonehostile - 15-06-2014
Oh I can assure you it did :p
RE: Ozonehostile Blurple gti6 - ozonehostile - 16-06-2014
New shiny!
[Image: 20140616_101207_zpsgyj6vtwu.jpg]Bargain baker bm quickshift, will fit when I do the bottom engine mount at some point this month in time for pugfest.
Also putting aside some cash for some epic ninja stuff I've got going on ninja ninja ninja
RE: Ozonehostile Blurple gti6 - Piggy - 16-06-2014
Get some shims ready for that quickshift....you'll find the shaft is too small for the locking collars Smile
(16-06-2014, 12:10 PM)Piggy Wrote: Get some shims ready for that quickshift....you'll find the shaft is too small for the locking collars Smile
Hmm thanks for the heads up
Might weld a sleeve around it where the collar sits or something?
RE: Ozonehostile Blurple gti6 - zx_volcane - 16-06-2014
yeah do something about it as they work loose instantly, and then the grub screws round off so you can't get them off and yer gearstick will be up and down like a merry man's bottom
Haha I'll look into it.
So the main problem is that the 306 shaft isn't wide enough yes?
Yeah exactly that.
I ended up marking where I wanted it and welding the bottom collar onto the 306 stick.
Then using shims for the top one
(16-06-2014, 12:36 PM)Piggy Wrote: Yeah exactly that.
Ah cool, I'll do that then
