XUD TDT- Status = SELLING ALL THE BITS. - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Photos and Projects (https://www.306oc.co.uk/forum/forumdisplay.php?fid=20) +--- Forum: 306 Projects (https://www.306oc.co.uk/forum/forumdisplay.php?fid=3) +--- Thread: XUD TDT- Status = SELLING ALL THE BITS. (/showthread.php?tid=20381) |
RE: XUD TDT- Status = Frame Building - Piggy - 02-03-2014 (01-03-2014, 06:15 PM)Grant Wrote:(01-03-2014, 07:34 AM)Piggy Wrote: ...and surely a gearbox isnt 40kg?! Yeah a number of times, on my own, on a gravel drive. And Im only 55kg, not the biggest of guys and didnt struggle RE: XUD TDT- Status = Frame Building - Rippthrough - 02-03-2014 6 speed box is definately over 40kg, the 5 speed is about 3-4kg lighter at most. Obviously not including flywheel or clutch weights. RE: XUD TDT- Status = Frame Building - Wor Jimmy - 02-03-2014 (02-03-2014, 12:21 AM)Piggy Wrote:(01-03-2014, 06:15 PM)Grant Wrote:(01-03-2014, 07:34 AM)Piggy Wrote: ...and surely a gearbox isnt 40kg?! I will weigh the gearbox next time i get in the garage RE: XUD TDT- Status = Frame Building - Danny2009 - 02-03-2014 Think the box weighs 38kg I have been told as I was posting one and the courier wouldn't take over 40kg RE: XUD TDT- Status = Frame Building - Wor Jimmy - 12-03-2014 Front end is slowly coming together Once i tac weld the frame. Wishbones are next. RE: XUD TDT- Status = Frame Building - Dum-Dum - 12-03-2014 Your missing a trick with that back wheel. weld a sprocket to one of the shafts and have 3 wheel drive RE: XUD TDT- Status = Frame Building - Rippthrough - 12-03-2014 Err, just looking at your bushes for the pivots - why have you got no crush tubes? You're not going to just try to let it pivot on the bolt are you?! And be very careful using the outer rose joints in shear like that, generally they need to be very oversized to last as the stress concentration across the thread root means the fatigue rate is insane. RE: XUD TDT- Status = Frame Building - Wor Jimmy - 12-03-2014 (12-03-2014, 09:02 PM)Dum-Dum Wrote: Your missing a trick with that back wheel. weld a sprocket to one of the shafts and have 3 wheel drive Thought about it.. the torque+added load might just snap the chain lol (12-03-2014, 09:08 PM)Rippthrough Wrote: Err, just looking at your bushes for the pivots - why have you got no crush tubes? True on the rose joints, I don't mind altering at a later date. If you saw the 1.25" Tube i used to demonstrate the fittings for the bushes. its reamed to 25mm, Sliding fit for the bosses that are threaded for the rose joints. I forgot to show it, but they are getting welded on and the boss with slide in. so i can swap it out for a larger drilled/threaded boss. if needed. (probs will now ) Quick pic :: as for the bushings sleeves, I can sharp stick the bushes back in the lathe. just for now i wanna make sure its going to work. I was going to Drill and tap one side of the brackets M10. Through hole on the other side. so i could side the bolt in.. nip it up snug then put a lock nut on. that way it SHOULD NOT.. need a sleeve (I say that but if it doesnt work.. Thats my problem ) lol... Cheers for pointing out the rose joint though RE: XUD TDT- Status = Frame Building - Rippthrough - 13-03-2014 You'll need a sleeve, as soon as the bush grabs the joint it'll spin or bend the bolt, and that's not even accounting for any debris or surface corrosion, if you don't have a sleeve that you can torque the bolt up against, your end plates are nowhere near as stiff as they could be and you also have no good way of controlling the end float on the bush without them binding. Re: XUD TDT- Status = Frame Building - Wor Jimmy - 13-03-2014 Sleeves it is then! Lol cheers RE: XUD TDT- Status = Frame Building - Wor Jimmy - 16-03-2014 (13-03-2014, 09:32 AM)Rippthrough Wrote: You'll need a sleeve, as soon as the bush grabs the joint it'll spin or bend the bolt, and that's not even accounting for any debris or surface corrosion, if you don't have a sleeve that you can torque the bolt up against, your end plates are nowhere near as stiff as they could be and you also have no good way of controlling the end float on the bush without them binding. Right, Redrilled the bushes 1/2". I had some 1/2" tube that I drilled out to 10mm (reamed) Did them 56.1mm long, The bosses with bushes installed are 56mm to prevent over tightening RE: XUD TDT- Status = On Hold - Wor Jimmy - 17-03-2014 On hold. Working on getting my bike back on the road for summer. Still buying parts, and doing little odd jobs. but mostly on hold RE: XUD TDT- Status = Back on track - Wor Jimmy - 06-04-2014 Right. Its back. Things getting done today. - Pump fitted - Timing belt - starter fitted - .. Stark realisation.... has it got oil.. f*ck brb RE: XUD TDT- Status = SELLING ALL THE BITS. - Wor Jimmy - 01-06-2014 I am no longer able to build the tike!.. Due to a couple of factors, it would of been nice to finish it, but the fact is I got a new got a month ago and with the hours i have 0 hours to play. Leaving the house 6:20 in the morning getting home 7 at night, Also I bought this.. So yeah selling all the bits! XUD Engine Lucas Pump (with inj) Starter motor Struts .. Cant sell the hubs due the modification RE: XUD TDT- Status = SELLING ALL THE BITS. - Poodle - 02-06-2014 Disappointing. Congratulations on the new job though. |
