Finally got it plugged in - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: DW10 HDi section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=10) +--- Thread: Finally got it plugged in (/showthread.php?tid=32928) |
RE: Finally got it plugged in - Toms306 - 03-03-2016 Everyone except welshpug...he 'corrects' it every time it comes up...
RE: Finally got it plugged in - aaron_one - 03-03-2016 Yeah it does come up, iirc there's 2 types of BSI, the above mentioned one being the 'better'. But yeah everyone even auto electricians and ProSteve even know it as a BSI. It's debates like that, which cause confusion for people! RE: Finally got it plugged in - Piggy - 03-03-2016 good news...so its staying in your possession? RE: Finally got it plugged in - aaron_one - 03-03-2016 Certainly is, I was going to fix it and sell it but I'm thinking twice now it's running. RE: Finally got it plugged in - Poodle - 03-03-2016 (03-03-2016, 09:04 AM)aaron_one Wrote: Yeah it does come up, iirc there's 2 types of BSI, the above mentioned one being the 'better'. But yeah everyone even auto electricians and ProSteve even know it as a BSI. It's debates like that, which cause confusion for people! I might start kicking off every time somebody calls a Rzeppa joint a cv joint because it's not the precisely correct technical term. Or i could continue having a life, hmmm....
RE: Finally got it plugged in - Piggy - 03-03-2016 Or a lamp, a bulb?
RE: Finally got it plugged in - Toms306 - 03-03-2016 (03-03-2016, 07:42 PM)Piggy Wrote: Or a lamp, a bulb? Let's not start that one...
RE: Finally got it plugged in - toseland - 04-03-2016 (03-03-2016, 07:16 PM)Poodle Wrote:(03-03-2016, 09:04 AM)aaron_one Wrote: Yeah it does come up, iirc there's 2 types of BSI, the above mentioned one being the 'better'. But yeah everyone even auto electricians and ProSteve even know it as a BSI. It's debates like that, which cause confusion for people! Piggy? is that you? oh wait. you actually know what you're talking about in the first place! RE: Finally got it plugged in - Poodle - 04-03-2016 You say that, Ruan rightly pointed out earlier that 306s don't use Rzeppa joints.
RE: Finally got it plugged in - toseland - 04-03-2016 Surely, in the interest of being anal, an rzeppa is still a TYPE of constant velocity joint... RE: Finally got it plugged in - Piggy - 04-03-2016 They are constant velocity joints...as said, rzeppa is just a type of one. But... I did always think that rzeppa design cv's were used? At least the outer two? I mean they aint bendix-weiss are they?! RE: Finally got it plugged in - toseland - 05-03-2016 No, they are the ball and grove type, but a slimmed down version.. in principle still rzeppa but with 3 balls instead of 6. Cheap bastards RE: Finally got it plugged in - Piggy - 05-03-2016 I thought they were 6 balls?! Lol RE: Finally got it plugged in - toseland - 09-03-2016 I pulled my nackered one apart.. the same as the Rzeppa in principle but with half the bearings, so it still works but not quite as smooth and weaker.. not a huge issue on that though as the breaking point will unlikely to be found on most cars and this certainly wouldn't be the weakest point of the drivetrain by a long shot. RE: Finally got it plugged in - pro_steve - 14-03-2016 Forgot about this one, glad you got it running. Texton box on the 306s, BSI on everything else. It's the same thing, just the box which links the immobiliser to the engine ECU. Glad you got it running, and good to see I was right on the BSI front too
RE: Finally got it plugged in - pug306driver - 05-04-2016 is there a guide or instructions for pp on here anywheres, its loaded on the laptop and seems to work, but before i connect it to the car, i would like some instructions. or do i follow the on screen prompts?? also where is the build code on the car? 306 2l hdi ph3 estate 1999 RE: Finally got it plugged in - mr_fish - 05-04-2016 PP2000 Guide There you go Behind the passenger side strut top I believe for the build code. RE: Finally got it plugged in - pug306driver - 05-04-2016 thank you thank you thank you!! RE: Finally got it plugged in - pug306driver - 06-04-2016 RE: Finally got it plugged in - Toms306 - 06-04-2016 That's the sticker, 8207 is your build code. RE: Finally got it plugged in - pug306driver - 07-04-2016 thanks all, will be having fun this weekend after playing with pp first. I have a feeling there may be more questions, but that's for later. RE: Finally got it plugged in - welshpug - 07-04-2016 (05-03-2016, 07:50 PM)toseland Wrote: No, they are the ball and grove type, but a slimmed down version.. in principle still rzeppa but with 3 balls instead of 6. Cheap bastards sounds like a base model el cheapo shaft, anything decent will have a full 6 ball outer CV and a sliding tripod inner |
