just another gti6 - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Photos and Projects (https://www.306oc.co.uk/forum/forumdisplay.php?fid=20) +--- Forum: 306 Projects (https://www.306oc.co.uk/forum/forumdisplay.php?fid=3) +--- Thread: just another gti6 (/showthread.php?tid=17586) |
RE: just another gti6 - fatlapit - 13-01-2016 Yeah man cheers ratty. The car is on a diet atm. Fitting different seats a load of weight has been removed. Carbon door cards and footwells. Converted the doors to manual winders and mirrors. Put the fuel pressure up and got a new pro alloy inter cooler also. RE: just another gti6 - roland rat - 13-01-2016 What you hoping to get it down to weight wise? RE: just another gti6 - fatlapit - 13-01-2016 Hopefully near 1 ton but from the bulkhead back its 100 percent stripped ok ive still got a headlining. So my next plan is radical but if done well it should help no end without weakening the xar RE: just another gti6 - roland rat - 13-01-2016 Carbon panels? RE: just another gti6 - twangy - 13-01-2016 nice looking car , good job on motor RE: just another gti6 - fatlapit - 13-01-2016 Cheers twangy Spaceframe front end ratty RE: just another gti6 - fatlapit - 26-06-2017 reet guys small update so iv`e had the spoox box in now for about 500 track miles and about 800 road miles. All I can say is what an improvement in grip braking and overall acceleration. The 3j diff has been amazing cant believe how much difference specifically in the braking it has over the atb. had a couple of issues at croft. one was a broken oil cooler and a broken manifold. So now with all that repaired and a quick road test all seems well and ready for maore mapping at efi on Thursday ready for fcs then either snett or cadwell in august. Heres a quick spec: L44 PTT FROG Engine: Fully rebuilt 2046cc Rebored, decked and honed 87mm low compression pistons Forged conrods Balanced and lightened crank ACL race bearings Lynx power head bolts Skimmed head with oversized inlet valves Ports matched to inlet and exhaust manifold Stainless steel tubular manifold Garret gtx2867 turbocharger 650cc Asnu injectors omex 600 ecu Omex wiring harness Turbosmart compgate 40mm external wastegate Turbosmart 50mm dump valve Tubosmart FPR 1200 fuel pressure regulator Turbosmart in car boost controller 3" turbo back stainless steel exhaust using flowmaster silencers Nissan 200sx aluminium race radiator Mitsubishi evo 6 race intercooler Fabricated aluminium 2.5” boost pipes 2.5 bar map sensor Pipercross airfilter Vibra technics race engine mounts Mocal oil system with oil cooler and sandwich plate royal purple racing oil Coolant pipes fabricated Exhaust system fabricated Exhaust system heat lagged Boost circuit fabricated Bulkhead heat shield Gearbox Helix paddle race clutch Lightened and balanced flywheel Spoox time attack spec box 3J diff Brakes Front Tarox 330 10 pots Rear Standard callipers with wavy discs and ds2500 pads In car brake bias valve steel Braided flexi hoses New copper piping though out Millers dot 5 racing fluid Wheels and suspension OZ Leggenda 17" alloys AD08r for wet and road use OZ super legger 17” alloys semi slicks BC Racing coil overs with Baker BM camber adjustable top mounts on the front Peugeot sport 24mm torsion bars and 30mm anti-roll bar beam negative camber rear trailing arms bc racing shocks Vibra technics p bushes Solid rear axle mounts lowered all round and corner weighted Interior Sparco pro adv TRS 3" 4 point harnesse omp steering wheel Quick release wheel boss stack gauges for boost, exhaust temp and afr Swirl pot and uprated fuel pumps and fuel pressure regulator in boot area battery located to boot area wiring of the whole car has been thinned omp 6 point cage harness bar Fire extinguishes fitted in the cab Exterior front bumper modified for better cooling Fibre glass bonnet with vents carbon wing mirrors hopefully over winter a new intercooler should be here along with water meth. if you look closely there is a crack in the oil cooler in the blue circle that ended my day early at croft RE: just another gti6 - Stef205 - 29-06-2017 flash the tig over it that all i did with mine. |
