Ozonehostiles Blurple gti6. - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Photos and Projects (https://www.306oc.co.uk/forum/forumdisplay.php?fid=20) +--- Forum: 306 Projects (https://www.306oc.co.uk/forum/forumdisplay.php?fid=3) +--- Thread: Ozonehostiles Blurple gti6. (/showthread.php?tid=22207) |
RE: Ozonehostiles Blurple gti6. Jenveys coming soon - Magenta Sunset - 25-04-2016 what's? the plywood for? RE: Ozonehostiles Blurple gti6. Jenveys coming soon - cully - 25-04-2016 (25-04-2016, 08:53 AM)Magenta Sunset Wrote: what's? the plywood for? its a copy of the Peugeot tool for locking the camshaft pulleys to enable the centre bolt to be torqued up correctly RE: Ozonehostiles Blurple gti6. Jenveys coming soon - Magenta Sunset - 25-04-2016 (25-04-2016, 09:03 AM)cully Wrote:(25-04-2016, 08:53 AM)Magenta Sunset Wrote: what's? the plywood for? clever stuff!
RE: Ozonehostiles Blurple gti6. Jenveys coming soon - ozonehostile - 25-04-2016 Ah nice one cully, I was trying to think of who I'd seen that had made something for the job RE: Ozonehostiles Blurple gti6. Jenveys coming soon - Stef205 - 25-04-2016 pin the flywheel and the cam pulleys job done RE: Ozonehostiles Blurple gti6. Jenveys coming soon - Eeyore - 25-04-2016 My bodies are fitted... I win. You lose. WINNNARRRR those arches look mint... Mine do not... I'm jealous... RE: Ozonehostiles Blurple gti6. Jenveys coming soon - Matt-Rallye - 26-04-2016 (25-04-2016, 07:02 PM)Eeyore Wrote: My bodies are fitted... I win. You lose. WINNNARRRR Yeah but sam you havent even taken your skirts off so when your car snaps in half from bwarps and zakks does not.. our reasoning will make sense
RE: Ozonehostiles Blurple gti6. Jenveys coming soon - Toms306 - 26-04-2016 It won't snap in half, the skirts are holding it together fine atm...
RE: Ozonehostiles Blurple gti6. Jenveys coming soon - ozonehostile - 30-04-2016 Not much done recently, but I've been cleaning bits whilst they're off the car, it's the little things that count when trying to tidy up an ageing car like these 306s ![]()
RE: Ozonehostiles Blurple gti6. Jenveys coming soon - Paul_13 - 30-04-2016 Dishwasher?
RE: Ozonehostiles Blurple gti6. Jenveys coming soon - ozonehostile - 30-04-2016 (30-04-2016, 07:14 PM)Paul_13 Wrote: Dishwasher? Steam cleaner haha RE: Ozonehostiles Blurple gti6. Jenveys coming soon - ozonehostile - 01-05-2016 Matt came over today and shit got done for once ![]() Cambelt is now spot on after making some tools to tension it properly and make the job alot easier in the future, quite glad I did decide to do the belt as it was looking a bit worn and to me seemed a bit slack. Also started to put my new beam back together with the powdercoated bits and new wheel bearings RE: Ozonehostiles Blurple gti6. Jenveys coming soon - Iaitoo - 01-05-2016 (01-05-2016, 06:53 PM)ozonehostile Wrote: Matt came over today and shit got done for once What size are those bolts? Replacing my beam soon, and would be nice with some new nuts and bolts
RE: Ozonehostiles Blurple gti6. Jenveys coming soon - ozonehostile - 01-05-2016 All the bolts on the rear beam are various lengths of m12 and m8 RE: Ozonehostiles Blurple gti6. Jenveys coming soon - welshpug - 01-05-2016 and m14. RE: Ozonehostiles Blurple gti6. Jenveys coming soon - ozonehostile - 02-05-2016 New beam ready to bolt up. It looks too good to fit to the underside of a car haha RE: Ozonehostiles Blurple gti6. Jenveys coming soon - Stef205 - 02-05-2016 looks good zac! id advise you turning the rear mounting bolts around tho as you may not be able to get them out again when needed. RE: Ozonehostiles Blurple gti6. Jenveys coming soon - ozonehostile - 02-05-2016 (02-05-2016, 07:42 PM)Stef205 Wrote: looks good zac! id advise you turning the rear mounting bolts around tho as you may not be able to get them out again when needed. Ah good point actually, I'll change them around tomorrow
RE: Ozonehostiles Blurple gti6. Jenveys coming soon - Stef205 - 02-05-2016 just dont make the misstake with the top shock bolt!
RE: Ozonehostiles Blurple gti6. Jenveys coming soon - MY95 - 02-05-2016 Looks good, that beam is soo shiny! What rear hubs/wheel bearings did you use? they look as shiny aha, got some conti direct continentals to go on mine
RE: Ozonehostiles Blurple gti6. Jenveys coming soon - ozonehostile - 03-05-2016 (02-05-2016, 11:25 PM)MY95 Wrote: Looks good, that beam is soo shiny! What rear hubs/wheel bearings did you use? they look as shiny aha, got some conti direct continentals to go on mine I got a pair of FAG rear hub assemblys, try to only use skf or fag when it comes to bearings for anything as that's what would be oem fitted by pretty much every manufacturer RE: Ozonehostiles Blurple gti6. Jenveys coming soon - MY95 - 03-05-2016 Ah cheers Ozone Will see how these will last, were only £28 posted so!I also have solid beam mounts and really like them, can get a little more skittish over rough ground though compared to standard mounts though, other than that and a bit more vibration, I find them really good Future/coming up shortly plans for your car?
RE: Ozonehostiles Blurple gti6. Jenveys coming soon - Stef205 - 03-05-2016 fag is genuine aswell
RE: Ozonehostiles Blurple gti6. Jenveys coming soon - ozonehostile - 03-05-2016 Tonights activities mostly involved un-seizing this wonderful contraption.... All great when it works but it had managed to seize fully closed this time, took alot of plusgas to get it moving at all! Hopefully it should be good for a while after the cleaning it's going to get ![]() Oh, and I changed the bolts around on the beam for future ease of beam mount removal RE: Ozonehostiles Blurple gti6. Jenveys coming soon - ozonehostile - 10-05-2016 Boot floor is finished now, just got a lot of masking tape to peel off and brake lines to put back on, then time to fit the new beam RE: Ozonehostiles Blurple gti6. Jenveys coming soon - Piggy - 11-05-2016 Looking good pal....considering hidden brake lines like the scoobys n evos?! RE: Ozonehostiles Blurple gti6. Jenveys coming soon - ozonehostile - 11-05-2016 (11-05-2016, 05:09 AM)Piggy Wrote: Looking good pal....considering hidden brake lines like the scoobys n evos?! Eventually Yeah, I'd like to sack off the compensator too eventually and go for a manual bias valve but at the moment I'm having to compromise on some things so that it actually gets on the road this year.. RE: Ozonehostiles Blurple gti6. Jenveys coming soon - Matt-Rallye - 11-05-2016 Thats looking good now mate give me a call when you wanna get the beam on and we'll have an evening on it
RE: Ozonehostiles Blurple gti6. Jenveys coming soon - ozonehostile - 14-05-2016 Refurbished brake compensator back together and painted And finally have the new beam fitted! Bit of a balancing act with a couple of jacks and several axle stands doing it by myself but wasn't too bad really Also got the rear bumper back on and I'll start to refit all the brake lines etc tomorrow RE: Ozonehostiles Blurple gti6. Jenveys coming soon - ozonehostile - 15-05-2016 Got a couple more hours in today, beam mounts tightened, hub nuts tightened (200nm!), brake lines all cleaned up a treat with some thinners and started to put all the brackets and heat shields I had powdercoated back on. Just have an order I'm waiting for from spoox motorsport to arrive then that should be everything I need to get it back together and ready for pugfest |
