Another XUD - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: Another XUD (/showthread.php?tid=8126) Pages:
1
2
RE: Another XUD - Ricky - 19-01-2013 Yeah, straight swap. RE: Another XUD - Nikolov_BG - 19-01-2013 But only the pump and the injectors,right? RE: Another XUD - Ricky - 19-01-2013 What do you mean? The older full manual pump will go straight on, along with the injectors. Although you can use your current injectors. RE: Another XUD - Nikolov_BG - 19-01-2013 And what about the smart injector? RE: Another XUD - Ricky - 19-01-2013 you mean the one with the wire? If so that will be fine just cut the wire off, its not needed. I have a 406 XUD in my 306 and I'm running a manual pump with the original injectors. RE: Another XUD - con67 - 19-01-2013 leave the injector etc in and get ppo then you really play with the advance springs/ip. RE: Another XUD - Nikolov_BG - 19-01-2013 what is ppo? RE: Another XUD - con67 - 20-01-2013 Peugeot planet, its a diagnostic interface that will let read live data from the engine ecu like rpm/advance/tps, most go by ear with advance/dynamic advance. RE: Another XUD - Nikolov_BG - 20-01-2013 Thanks ;] RE: Another XUD - Nikolov_BG - 05-02-2013 Another question: Whant nozzles I must use?...from 2.1 maybe?
