Gearbox failure - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Suspension, Transmission, Handling & Braking (https://www.306oc.co.uk/forum/forumdisplay.php?fid=19) +--- Thread: Gearbox failure (/showthread.php?tid=34101) Pages:
1
2
RE: Gearbox failure - Ruan - 24-05-2016 Interesting, probably is worth sandwiching a plate between the end of the casing and the cover. Looks like it'd be much more of a bastard to put something on the other end, but every little helps eh. RE: Gearbox failure - Rippthrough - 24-05-2016 Used to run external straps on the old VW transaxles to stop them splaying apart under shock. The pegs behind the shafts and diff. RE: Gearbox failure - miles - 24-05-2016 Everyone has there ways, I know AB motorsport used a larger bearing on the input shaft end which some BTCC box's did but as WP said the gap then between the 2 bearings in the end case got so close it cracked, well on the BTCC ones, you even need to watch when fitting a single plate Race clutch the clutch arm top bearing area can fail as well due to the extra load on it. Old race box's I did used Roller bearings instead of the bush's which these days for some reason seems all to be forgotten about RE: Gearbox failure - allye - 11-06-2016 If you are smashing gear boxes all the time I'd suggest you start looking at your driving style even with higher than normal outputs. ML gear boxes are a huge amount stronger and a avenue worth Investigsting at some point for sure. I've never heard of a V6 killing one, I curtainly gave mine some stick and plenty of hard launches. I even drove it 80 miles with no clutch, bumping it on the starer every junction! Down side to that is gear cables do not give a nice change compared to a well sorted rod set up in my opinion. |
