Paodl: '98 306 GTi-6 - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Photos and Projects (https://www.306oc.co.uk/forum/forumdisplay.php?fid=20) +--- Forum: 306 Projects (https://www.306oc.co.uk/forum/forumdisplay.php?fid=3) +--- Thread: Paodl: '98 306 GTi-6 (/showthread.php?tid=33017) Pages:
1
2
Paodl: '98 306 GTi-6 - Paodl - 04-03-2016 Got this shortshift bracket with the car, is it worth mounting? ![]() RE: Paodl: '98 306 GTi-6 - Yankee - 04-03-2016 Try it, you never know ![]() Paodl: '98 306 GTi-6 - Paodl - 04-03-2016 (04-03-2016, 02:26 AM)Yankee Wrote: Try it, you never know For me who is used to sloppy Volvo transmission, the Peugeot shifting is a dream already :p But I was thinking more like if anyone have any experience with it? Paodl: '98 306 GTi-6 - Paodl - 09-03-2016 Weight reduction bro? ![]() Paodl: '98 306 GTi-6 - Paodl - 10-03-2016 Just curious; I've got a manifold similar to this, is this the original manifold? ![]() RE: Paodl: '98 306 GTi-6 - Yankee - 10-03-2016 Don't think so, looks aftermarket RE: Paodl: '98 306 GTi-6 - puggered - 10-03-2016 Standard 6 manifold. Paodl: '98 306 GTi-6 - Paodl - 10-03-2016 Thanks Paodl: '98 306 GTi-6 - Paodl - 16-03-2016 ![]() Some wiring removed RE: Paodl: '98 306 GTi-6 - Eeyore - 16-03-2016 Good work. That bit on the boot trim isnt standard. The exhaust manifold is standard gti6 and is really good. 421 doesnt have much advantage. Paodl: '98 306 GTi-6 - Paodl - 16-03-2016 I found out that the bit was a piece of the DEFA pack, but none of that worked, so I took it out (as you can see in the pic). I was quite suprised about the manifold as it looks aftermarket, compared to "standard" cars. All the other cables are double up with speaker cables, I don't know why, but they weren't any good anyways so.. There are some cables in the back that has been cut, and I suspect that's the original cables. I also removed the Alpine head unit with all its cables aswell, already posted pic, but here you go: ![]() Alpine unit on the right; even though it has an extra amplifier, the Sony player on the left does the job better, mostly because the settings on the Alpine were "crap". The only sound system that's in the car right now is the Alpine front set (speaker+tweeter) in the doors, and it's playing quite good, actually. I haven't decided yet if I'm going to use the subwoofers, as they're quite heavy, but maybe it's good to have them there since all the weight is in the front of the car, hehe. ![]() This might explain the weight. It's when these plays that I can hear that the car has been built with thin steel.. Standard size spray can for measure :p Paodl: '98 306 GTi-6 - Paodl - 19-04-2016 Which oil goes in the gearbox? Original 6spd RE: Paodl: '98 306 GTi-6 - Piggy - 20-04-2016 Total BV...now called Total Gear 8 ![]() You'll need 2 litres ![]() |
