HDI FPR - Printable Version
+--- Forum: DW10 HDi section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=10)
+--- Thread: HDI FPR (/showthread.php?tid=22229)
Pages: 1 2
RE: HDI FPR - Poodle - 19-03-2014
So that's cutting out on the second and third runs of five..?
Ok quite a low mileage engine then. I'd say its looking most like injectors at the moment, we'll do a leak-off test on Sunday if you like.
HDI FPR - mattgreene - 19-03-2014
Yeh that would be good thanks, it cut out on the third run I'm 2nd gear, and the second run in 3rd gear
Right, so it's not down to the fuel heating up then, in which case we can probably rule out lp pump for now...
I really must get PP2000 working lol.
RE: HDI FPR - pro_steve - 19-03-2014
Who's map is it on?
If it's only cutting out occasionally the pump is most likely on it's way out, I can stop that if you don't want to fit a new one.
RE: HDI FPR - mattgreene - 20-03-2014
Mr Whippy did me the map in January
RE: HDI FPR - pro_steve - 20-03-2014
Ok, you can either clean regulator/fit a new fuel pump (possibly injectors), or get dave to raise the limits at which the ECU shuts the engine off.
The first is the best solution but on some of the earlier ECUs (162, 163 1976) they tend to always have problems with cutting out unless these values are tweaked due the the way the ECU is set up from the factory.
Ah right, my car is 2000 v reg, would it be in one of those ecu groups?
RE: HDI FPR - HDi--Power - 20-03-2014
No you probably have a 362 Ecu, the cutting out business was a ridiculous feature added, all the later cars now go to limp mode instead of cutting out as its so dangerous
I always thought that, imagine pulling out infront of somebody only to find peugeot programmed it to cut out, not a good plan at all!
RE: HDI FPR - Poodle - 21-03-2014
Yeah, first discovered that in the outside lane on a busy motorway, not cool.
RE: HDI FPR - mattgreene - 06-04-2014
All sorted now, ive cleaned the fpr and ive driven about 300 miles now and it hasn't cut out on WOT Smile
RE: HDI FPR - Poodle - 07-04-2014
Glad to hear it mate, always worth checking the little things. Smile
