307 crankshaft pulley
Right i got a clapety noise coming from my cambelt area that i think is my pulley,
I have orderd this 1 for a 307 2.0 hdi as its a solid unit so should be better?
[Image: B796F4D7-BF74-4634-88B8-EB2F879B31E2-162...4B1085.jpg]
Is there any other parts that i will need to change when swapping (new aux belt obvs)
Cheers guys
no. just the aux belt mate. Some people say a new bolt but i havnt. Just use some locktght.
Ahh sweet loctight it is then
Would this fit a 306 hdi? im on my 2nd now Sad this one has lasted about a year getting fed up of em grr (sorry if its a noob question lol)
Yes, thats the whole idea lol.
Yeah they fit the 306. I'll be upgrading mine after my holiday because my air con pump has gone so will be removing it with all new belts pullys and tensioners
nice think ill get one too, ive been looking at getting rid of the air con too might as well while im there lol Smile thanks for info guys
No probs. Smile The belt you'll need if you remove the aircon is a gates 6pk1175, or any 6-tooth belt that's ~1175mm long.
(11-04-2013, 02:38 PM)Poodle Wrote: No probs. Smile The belt you'll need if you remove the aircon is a gates 6pk1175, or any 6-tooth belt that's ~1175mm long.
Cheers poodle I was just going to ask aux belt kit for non air con
That's for if you had aircon as standard and have removed it - non-aircon models have a different routing and larger belt size. The ideal solution is to get hold of a setup off a non-ac engine, but they're fairly hard to get hold of.
(11-04-2013, 05:56 PM)Poodle Wrote: That's for if you had aircon as standard and have removed it - non-aircon models have a different routing and larger belt size. The ideal solution is to get hold of a setup off a non-ac engine, but they're fairly hard to get hold of.
Oh so I just need normal tensioners and the shorter Belt. Wicked
You got it man. Smile
  Crankshaft Pulley JTaylor2005 5 1,445 21-04-2018, 06:44 PM
Last Post: Frosty
  Crankshaft Pulley - removing bolt? CaptainHair 19 3,433 10-12-2016, 05:50 PM
Last Post: CaptainHair
  WARNING! Crankshaft pulley issues highwayman306 26 10,801 10-04-2015, 06:34 PM
Last Post: highwayman306
