phase 1 to phase 2/3 rear light conversion
As I cant seem to find any clear information about putting phase 2/3 rear lights onto a phase 1 i thought i would start this for my own use and for people doing future conversions.
first of all, i know that the light itself is a straight fit, but from there im not so sure.
what wiring differences are there between the different phase rear light clusters?
what do i need to do to wire in the lights?
Im fairly confident when it comes to electrical stuff, just want clear information before i attempt the conversion to save me having to figure out what to then, lazy i know but meh
so yeah..... GO Smile
you want the plugs from the p2/3 lights.
theres no crazy canbus so I would use a multimeter and a pad and start taking readings of what colour does what and go from there???
They're not strictly "straight" fit, the plug for number plate lights needs adjusting, either cut a bit of the metal so it slots through, or piggy back the wires straight off the sidelight wire. When I did mine mine, I just used a power probe and did it wire by wire. You'll also have to link the loom for the nearside cluster, as on a ph1 there is a plug from the offside that goes to the near side, its just a case of cutting the plug off and joining the right wires
look at this:
if you have the mk2/3 connectors is much better
[Image: sign.png]
↑ Project ↑
thats ubber helpful...nice one
cheers for the info guys, that diagram is spot on cheers Smile
Or you could just use phase 1 Lexus light looms Smile
No cuttin of wires that way
Erm.. pretty sure that diagram was wrong when I used it...
(26-12-2012, 02:56 AM)Seid Wrote: look at this:
Repped for this very usefull, i will pinch this and put it in guides for future use
  306 xsi phase 3 central locking issue!!! Seabrook3607 2 1,442 16-01-2016, 08:02 PM
Last Post: Seabrook3607
  1.6 Phase 3 Dash Board Issue Jama 3 2,331 09-09-2015, 02:05 PM
Last Post: Jama
  PHase 1 3 door bouncing window?? Redordead89 2 1,467 21-07-2015, 09:28 AM
Last Post: Toms306
