Heater blower motor speed issue
When I have the blower set to max(most of the time as the matrix is blocked and needs replacing) the motor changes speed with the revs. This only happens on max setting.
Is the dash panel or the motor fubar'd or is there a rheostat somewhere that may be at fault and I can change? If so where and how easy a job is it?
Cheers gays Smile
Resistor pack
Heater controls
Dodgy blower motor
I have a bfo pikey hammer and will fix it for you :p
Where's the resistor pack?
You still ain't fixed your recip saw yet lol
On the pass side under the scuttle panel and behind the so called pollen filter Wink should have spares but only £14 if that new on eBay last time I looked.
You using the heated rear screen while it does it?
Ahh - scuttles gotta come off again at some point anyway sort that washer pipe out lol. Wasn't there a thread on the other site about cleaning and adding filters? as that's a job that may as well be done whilst the scuttle is off lol.
Filter is probably missing anyway mate that or f*cked lol easy enuff job to do
And no Cba with recip saw may just buy one not much new Smile
  306 Blower motor replaced and working but no air coming from vents? Zubes3 4 1,337 19-09-2020, 04:58 PM
Last Post: Zubes3
  Heater controls - direction issue stalker92 3 2,272 22-12-2018, 09:43 AM
Last Post: pug306driver
  Heater blower issues Dturbo john 5 2,719 13-03-2018, 01:53 PM
Last Post: Toms306
