Brake Bleed Nipple size
I know one of the sizes but i thought if they all here would make it easier to know what size to get if their's shear Doh
Sizes are thread size by thread pitch. Google never threw anything so this would be a port of call for people. Also all sizes are outer diameter's of discs/drums. Also adding pug part number after in brackets
If you know a size reply and as people add sizes i'll edit this post accordingly
Fronts
247mm solid = M7x1mm (4428 13)
247mm vented =
266mm = M10x1mm (4428 46)
283mm = M10x1mm (4428 46)
Brembo 4 pots = M10x1mm (4428 46)
Rears
Discs 247mm = M7x1mm (4428 13)
Drums 212mm =
Drums 247mm =
Drums 274mm =
Hope this helps
Fronts 283mm discs 11mm nipples
is that thread and do you know the thread pitch?
Ohh, thought you meant the head size. And for that reason, i'm out
Thats ok and apparently front 247mm are M7x1mm too but would like someone to confirm that
Yes the 247 are m7
All of these I can supply in stainless steel
How much for a set of nipps swampy front and rear gti setup?
[Image: SDC10442-1.jpg]
thanks swampy and can i get a price on stainless steel ones rear discs and fronts that are 266mm discs please?
They aint cheap!!
But then again nothing on stainless is cheap!!
Once we have a full list of sizes I will get the prices as I can't find the list I had
I know done calipers use m7 some m8 and some m9
Cheers
well found out in 266mm there was 4 different ones used by Peugeot on 306's, 2 Lucas and 2 Bosch and 283mm was only gti-6 but no closer to finding nipple sizes......
The only 247 fronts that use the m7x1 bleed screw are the non-vented type, as per poverty spec 1.4's.
The vented 247's use a lot bigger bleed screw.and completely different thread. Couldnt tell you what it is.
[Image: KrisB-new-Logo11.gif]
edited first post Kris to take that into account
I'm sure my s16 calipers used an m7
Here we go for prices
MILD STEEL
M7 x 1 £1.50
M8 x 1 £1.50
M10 x 1 £1.90
STAINLESS STEEL
M7 x1 £3.25
M8 x 1 £6.50
M10 x 1 £6.00
Prices are each and plus postage
Cheers
discounts on multiple orders swampy?
Can do a bit but it's more the postage that I'll be removing
ok cool just got to work out these sizes now lol
Gti6 and BREMBO 4 pots are m10 x 1
Remember folks, you need an 8-sided spanner for this job...
/troll.
[Image: Sig500x130.png]
Edited post swampy and C.A.R is that if Stevie is doing it?lmfao
Looking good swampy, if my current plans go ahead I'll be having a word. Less chance of sheering would be nice Smile
right done some digging on service box and found out that 266mm are the same as 283mm so that size is done.
part number 4428 48 is for 247mm (as a thought i'm gonna add pug part numbers to original post) and 4428 46 for 266mm/283mm/brembo's and 4428 13 for front and rear non vented discs
also people if you know sizes or can measure some help out lol
  Any tips for undoing rear bleed nipples on calipers? Tom85 18 4,600 27-06-2016, 07:39 PM
  Removing broken bleen nipple/How many types of rear calipers? Iaitoo 16 4,770 31-03-2016, 02:25 PM
Last Post: pug306driver
  Brake Bleed Nipple Specs Toms306 16 4,837 22-01-2016, 05:21 PM
Last Post: Toms306
