Air leak fuel filter housing
Just a simple quistion i think i have air leak on the fuel filter housing, i have just ordered new fuel pipe return pipelines 3,5mm normal 3,4mm but does not have so 3,5 would work fine i quess. (internal diameter)
The problem is white smoke and rough starting so i quess after changing fuel filter there is an air leak on the fuel filter housing.
My quistion? is it possible to put on some seal tube on the filterhousing to make it good air tight?....Smile
[Image: 62941977.jpg]
(27-09-2012, 12:22 PM)306__xrdt Wrote: Just a simple quistion i think i have air leak on the fuel filter housing, i have just ordered new fuel pipe return pipelines 3,5mm normal 3,4mm but does not have so 3,5 would work fine i quess. (internal diameter)
Putting seal in the filter housing IMO is a massive no, make sure the little turny cap at the front of the housing is tight.
Fabia vRS PD130 - New daily
Astra H VXR - new toy!
Ok Smile
Just use a universal fuel filter like this http://www.ebay.co.uk/itm/1X-LARGE-IN-LI...1e6c76c299
Bye Bye D-Turbo
Ah ok thanks m8 il check it out Wink
  Filter housing replacement weka 2 1,525 25-08-2017, 06:16 PM
Last Post: weka
Exclamation Swarf In Fuel Filter Housing jordanhdi 11 2,408 26-09-2016, 11:55 AM
Last Post: pug306driver
  Major fuel pump problems, air leak, head gasket? Dantheman1312 2 2,234 22-08-2016, 09:57 AM
Last Post: r3k1355
