Quick oil pump pressure Q.
Is there any difference between the hdi/xud oil pump spring rates?
Thd hdi oil pump i have is a low milleage one so i'm putting that on my xud, along with the xud strainer (as it looks different) and xud pressure relief spring... but if the hdi oil pressure is the same as xud, i'll leave the hdi spring in.
(The hdi has hydraulic lifters so i'm guessing they have different pressures?)
Cheers
Edit; SORTED. For future searches...
XUD;
5.0 bar @ 4000rpm
HDi;
4.0 bar @ 4000rpm
[Image: brokendown-1-1-1.jpg]
Dturbo GT2259s build thread;
Not sure about the Hdi But the XUD standard is 3bar
i uprated my XUD oil pump spring from a 3bar spring to 6bar spring and engine turned into a siv and then had to fix all leaks :S
[Image: J5hxCcC.jpg]
  Quick Fuel Pump Question lazareth1 5 1,404 28-07-2013, 10:37 AM
Last Post: lazareth1
  Are cylinder pressure and boost pressure inextricably linked Flynn 55 7,180 18-01-2012, 08:19 PM
Last Post: Matty
