HDi Cuts Out
HDi Cuts Out
When giving her full throttle changing up to 2nd into 3rd car brutally cuts out. Brings up engine light, takes a second for it to start again and when she does start up again the engine light is gone and drives perfect again. Only happens some times when I give it full throttle not all the time. I can usually go full throttle from 2nd to 3rd 2-3 times and after that it will cut out once then be fine again. 2000 306 mapped to 140 ish with a hard cut limiter. Used to chug a lot at low revs before map and clean map sorted it
Worn HP pump, injectors, LP pump or shit map. Could be any of them.
The brutal cut out is simply is detecting Rail pressure too low and assuming a leak and cutting.
One of my injectors has a very slight leakage. The remap is quality definitely not that. Will try and see if I can do something with this injector or replace it. I cleaned it with brake cleaner a few weeks back and ran the engine again to see where it was leaking and seems to be from where it meets the fuel line. Probably due new injectors anyway. Thanks for the reply
(30-07-2019, 08:19 PM)RPug Wrote: One of my injectors has a very slight leakage. The remap is quality definitely not that. Will try and see if I can do something with this injector or replace it. I cleaned it with brake cleaner a few weeks back and ran the engine again to see where it was leaking and seems to be from where it meets the fuel line. Probably due new injectors anyway. Thanks for the reply
ps. The remap was done a few weeks ago. Was doing this before I got it remapped
An account of the motive and all shared opinions are met for future times. The sequence of the formal means and uk assignments review is designed for the approval of the terms for the candidates. It is stuffed for the mixed approach for the field of the accumulation of manners for the field.
  Cuts out at 2000rpm Dicky 3 1,643 23-10-2014, 09:48 PM
Last Post: Dicky
  Cuts out when driving Frosty 19 4,347 27-12-2013, 10:07 AM
  Hdi cuts out when accelerating hard hdi shaun 8 3,930 07-06-2013, 06:03 PM
