Damaged electrics, possibly relay??
Hi Everyone,
I've been doing a gearbox change on my 306 D'turbo, and found a couple of damaged electrical items that look like large relays, they appear as though they should be mounted on the back edge of the battery box or possibly on the inner wing in that area, somewhere very close to the glow plug control unit, but they were just hanging from the wiring loom and one has worn away as it has been in contact with the driveshaft, i want to replace the damaged item, but don't know what it is to buy a new one..... its tubular, about 50mm long, and about 30mm diameter, there are 2 that look the same hanging side by side along with my glow plug control unit..... any ideas?
  last "whats this for" on electrics pug306driver 3 1,580 18-02-2016, 09:30 PM
Last Post: pug306driver
  Test Rig for Tow Bar Electrics insomaniac45 24 6,029 07-12-2015, 07:23 AM
Last Post: THE_Liam
  Headlight Issue-B*stard Electrics at it again... Pug0BZ3011 11 3,981 04-02-2015, 05:19 PM
Last Post: powerandtorque
